R5p7 power #2798284
07/18/20 12:34 PM
07/18/20 12:34 PM
East Brunswick New Jersey
N
NoFrills Offline OP
NoFrills  Offline OP
N
Picked up my r5p7 last week. Had hopes. Of taking it to drag week. So far it impresses me. Made 813 hp. Its only a 11.1 357. I really need to get it in the car and see how it works out.
Re: R5p7 power [Re: NoFrills] #2798287
07/18/20 12:48 PM
07/18/20 12:48 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Nice!!
Peak HP at what rpm?
How high did you take it?
What was the peak tq, and at what rpm?
Re: R5p7 power [Re: fast68plymouth] #2798293
07/18/20 12:55 PM
07/18/20 12:55 PM
N
NoFrills Offline OP
NoFrills  Offline OP
N
I need to find the sheet torque was 560 i think both peaked about 8000 pulled to 9200 was still real happy
Re: R5p7 power [Re: NoFrills] #2798303
07/18/20 01:12 PM
07/18/20 01:12 PM
So. Burlington, Vt.
So. Burlington, Vt.
I bet that sounded killer.
No TCI Street Fighter converter for that combo smoke
Re: R5p7 power [Re: fast68plymouth] #2798348
07/18/20 02:57 PM
07/18/20 02:57 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
That little dude needs a stick and a bunch of gear, like the old Modified Eliminator cars. drive
Re: R5p7 power [Re: justinp61] #2798350
07/18/20 03:08 PM
07/18/20 03:08 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Very nice in deed.
Could you imagine with some 16:1 compression.
Re: R5p7 power [Re: justinp61] #2798351
07/18/20 03:09 PM
07/18/20 03:09 PM
N
NoFrills Offline OP
NoFrills  Offline OP
N
Its getting a clutchless g force 5 speed 3.29 1st with a black magic clutch 4.30 gear plan on shifting 1-4 at the track and 5th for the street
Re: R5p7 power [Re: NoFrills] #2798463
07/18/20 10:16 PM
07/18/20 10:16 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Wow
Re: R5p7 power [Re: Dragula] #2798543
07/19/20 10:09 AM
07/19/20 10:09 AM
Tulsa, Oklahoma
340Cuda Online content
340Cuda  Online Content
Tulsa, Oklahoma
That is very good!
Tell us a little more about the engine.
Did you go with wet sump?
Did you build it or buy it running?
Who were your parts sources?
Re: R5p7 power [Re: 340Cuda] #2798573
07/19/20 12:23 PM
07/19/20 12:23 PM
N
NoFrills Offline OP
NoFrills  Offline OP
N
It is dry sump. Still has the circle track cam 740 lift not sure of duration. I had bought 2 engines. The 1st was for arringtons auction was in there office as a display had a lot of new parts but was just a propped up display. The 2nf i actually bought off here. Was complete except pistons. It was a old gasoline alley Wayne Jessel engine. I met a guy Danny Glad from Glad precision machine in virgina. Initially i was looking for parts but ended up having him do all the work. I had issues with my block and its now mostly Dannys parts. I don't think i could have built anything comparable for a better deal.
Re: R5p7 power [Re: NoFrills] #2798623
07/19/20 03:02 PM
07/19/20 03:02 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
A friend of mine had one of the old Petty truck series engines on the shelf and for years I tried talking him into putting it into an old Pro-stock chassis he had in the shop with a Nash 5-speed. The chassis was originally set up with a Lenco so the conversion would be pretty easy. The way those engines scream it only makes sense to put one in front of a 5-speed box where it can stay up on the pipe during the run.
Should be an awesome ride up
Gus beer
64 Plymouth Savoy
Dana 60
Re: R5p7 power [Re: NoFrills] #2798706
07/19/20 08:15 PM
07/19/20 08:15 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
What kind of issues did you have with the block?
Alan Jones
Re: R5p7 power [Re: LA360] #2798738
07/19/20 09:37 PM
07/19/20 09:37 PM
N
NoFrills Offline OP
NoFrills  Offline OP
N
The block was cracked and repaired coolant passage to the outside near the oil.pan rail. It must have froze at some point because the water manifold was also cracked. The it was welded and held untill it started making power then it leaked. Tried to epoxy it and it broke on both sides of the epoxy. On r5s the water pump goes in the bottom of the block and the jacket is shaped like a cone to evenly distribute coolant. It cant really be filled to fix it because would fill the passage right up. The other block that i have has deck plugs in it. R5s are open decks this one is closed now. I think it would be good for boost but im told not good to drive 1000 miles.
Re: R5p7 power [Re: NoFrills] #2798750
07/19/20 10:17 PM
07/19/20 10:17 PM
LA360 Offline
LA360  Offline
I thought about filling the deck on my blocks, but decided against it. I've got two virgin early blocks that I am hoping to get started on this year some time
Alan Jones
Re: R5p7 power [Re: LA360] #2798755
07/19/20 10:22 PM
07/19/20 10:22 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
you have plenty of time down in mexico now grin
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: R5p7 power [Re: tex013] #2798789
07/20/20 12:29 AM
07/20/20 12:29 AM
LA360 Offline
LA360  Offline
Haha Tex, the way things are going, I won't be able to leave the house soon!
Alan Jones
Re: R5p7 power [Re: NoFrills] #2798867
07/20/20 10:33 AM
07/20/20 10:33 AM
Tulsa, Oklahoma
Tulsa, Oklahoma
Thanks for sharing!
Re: R5p7 power [Re: 340Cuda] #2798870
07/20/20 10:37 AM
07/20/20 10:37 AM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
Could I ask if you were using one of the STD. cams or did you have one ground.
STOP POTATO HATE!
Re: R5p7 power [Re: Mr PotatoHead] #2798886
07/20/20 11:18 AM
07/20/20 11:18 AM
N
NoFrills Offline OP
NoFrills  Offline OP
N
I still have the nascar cam in it. Learned that basically the roller ones are all around .750 lift older ones have around a .440 lobe newer have a .350 ish with a much bigger rocker. Also learned have to watch out for what cam gear it has on the back there where some different ones. Engine guy was very knowledgeable with r5 and r6s has a few dozen of them around his shop he had worked for Arrington for years and was involved with alot of the development. He had told me there is probably 25 hp in a purpose built cam but its going to be ruff on the valve train. I figured they had spent more money developing this stuff then i will probably ever make in my life why try and reinvent it. Would be different if i did not have to drive it track to track.
Re: R5p7 power [Re: NoFrills] #2798890
07/20/20 11:30 AM
07/20/20 11:30 AM
Super Spudsville
Half Baked
Half Baked
Super Spudsville
Great, thank you. You have a great build there. Seems hard to beat the fun/money spent factor.
STOP POTATO HATE!
