Re: R5p7 power
[Re: NoFrills]
#2798287
07/18/20 12:48 PM
07/18/20 12:48 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Nice!!
Peak HP at what rpm? How high did you take it?
What was the peak tq, and at what rpm?
Re: R5p7 power
[Re: NoFrills]
#2798303
07/18/20 01:12 PM
07/18/20 01:12 PM
fast68plymouth
So. Burlington, Vt.
I bet that sounded killer. No TCI Street Fighter converter for that combo
Re: R5p7 power
[Re: NoFrills]
#2798623
07/19/20 03:02 PM
07/19/20 03:02 PM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
A friend of mine had one of the old Petty truck series engines on the shelf and for years I tried talking him into putting it into an old Pro-stock chassis he had in the shop with a Nash 5-speed. The chassis was originally set up with a Lenco so the conversion would be pretty easy. The way those engines scream it only makes sense to put one in front of a 5-speed box where it can stay up on the pipe during the run. Should be an awesome ride Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: R5p7 power
[Re: NoFrills]
#2798706
07/19/20 08:15 PM
07/19/20 08:15 PM
Posts: 6,148 Melbourne , Australia
LA360
It is dry sump. Still has the circle track cam 740 lift not sure of duration. I had bought 2 engines. The 1st was for arringtons auction was in there office as a display had a lot of new parts but was just a propped up display. The 2nf i actually bought off here. Was complete except pistons. It was a old gasoline alley Wayne Jessel engine. I met a guy Danny Glad from Glad precision machine in virgina. Initially i was looking for parts but ended up having him do all the work. I had issues with my block and its now mostly Dannys parts. I don't think i could have built anything comparable for a better deal. What kind of issues did you have with the block?
Alan Jones
Re: R5p7 power
[Re: NoFrills]
#2798750
07/19/20 10:17 PM
07/19/20 10:17 PM
LA360
I thought about filling the deck on my blocks, but decided against it. I've got two virgin early blocks that I am hoping to get started on this year some time
Alan Jones
Re: R5p7 power
[Re: LA360]
#2798755
07/19/20 10:22 PM
07/19/20 10:22 PM
Posts: 2,469 Sydney,Australia
tex013
Sydney,Australia
I thought about filling the deck on my blocks, but decided against it. I've got two virgin early blocks that I am hoping to get started on this year some time you have plenty of time down in mexico now Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: R5p7 power
[Re: NoFrills]
#2798867
07/20/20 10:33 AM
07/20/20 10:33 AM
Posts: 3,525 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
It is dry sump. Still has the circle track cam 740 lift not sure of duration. I had bought 2 engines. The 1st was for arringtons auction was in there office as a display had a lot of new parts but was just a propped up display. The 2nf i actually bought off here. Was complete except pistons. It was a old gasoline alley Wayne Jessel engine. I met a guy Danny Glad from Glad precision machine in virgina. Initially i was looking for parts but ended up having him do all the work. I had issues with my block and its now mostly Dannys parts. I don't think i could have built anything comparable for a better deal. Thanks for sharing!
