Page 8 of 11 1 2 6 7 8 9 10 11
Re: Sleeper mopars..what do you like. [Re: bigtimeauto] #279658
12/05/09 12:45 AM
12/05/09 12:45 AM
Wow, some people's definition of sleeper and mine are obviously different.
Cowl hoods, big hoops and slicks scream "DRAG CAR" to me....
Re: Sleeper mopars..what do you like. #279659
12/05/09 12:49 AM
12/05/09 12:49 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Big forward facing hood scoops scream more than a cowl hood, sorry i didn't take the pic with the drag radials on it... and Whats a big hoop?
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Sleeper mopars..what do you like. [Re: bigtimeauto] #279660
12/05/09 12:55 AM
12/05/09 12:55 AM
Pewaukee, WI
Airgrabber Offline
Airgrabber  Offline
Pewaukee, WI
He's talking about the tires and wheels. Sleeper= 2 or 4 door sedan very lame and plain looking that kicks ass!
Re: Sleeper mopars..what do you like. [Re: Airgrabber] #279661
12/05/09 12:58 AM
12/05/09 12:58 AM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
mine are only true 10.5's in that pick i saw tubbed cars everywhere and i'm the one.....?
Re: Sleeper mopars..what do you like. [Re: bigtimeauto] #279662
12/05/09 01:18 AM
12/05/09 01:18 AM
Salisbury North Carolina
8secDart Offline
8secDart  Offline
Here are some more of Buster.The sleeper look is gone but the cool factor is out the roof.Lenny
Re: Sleeper mopars..what do you like. [Re: bigtimeauto] #279663
12/05/09 01:22 AM
12/05/09 01:22 AM
Cookeville
Chilort Offline
Will Work For Mopars
Chilort  Offline
Cookeville
I didn't go after you. I went after a car that's been attacked with a hole saw that has to have pistons replaced after every round.
Re: Sleeper mopars..what do you like. [Re: Chilort] #279664
12/05/09 02:55 AM
12/05/09 02:55 AM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
Before it was painted
Re: Sleeper mopars..what do you like. [Re: B1KILLER] #279665
12/05/09 11:23 AM
12/05/09 11:23 AM
The Hand
K
KRiTiK Offline
KRiTiK  Offline
K
The Hand
Just saw this on the "best 60' on street radials " thread . 11.70's with a stock sounding Slant Six & 5" wide street tires , that's a sleeper !!
http://www.youtube.com/watch?v=GMwcDlJGss0
Re: Sleeper mopars..what do you like. [Re: Ari440] #279666
12/05/09 01:10 PM
12/05/09 01:10 PM
toledo, ohio
plasticfantastic Offline
toledo, ohio
how did you get certified without a dash bar?
Post deleted by Defbob [Re: plasticfantastic] #279667
12/05/09 01:33 PM
12/05/09 01:33 PM
Re: Sleeper mopars..what do you like. [Re: B1Fish540] #279668
12/05/09 11:34 PM
12/05/09 11:34 PM
Missouri
bb74swngr Offline
mopar addict
bb74swngr  Offline
mopar addict
Missouri
Stock uncut body and interior (25K miles)
KG2 Frosty Green Metallic w/V1W white vinyl top
F3G6 green cloth and vinyl split bench seat w/center armrest
Weight – 3450#
Carpeting – Stockinteriors.com Jade Green cut pile (new)
Air conditioning – 134
Cruise control – OEM
Radio – AM OEM
Remote trunk release - OEM
Tachometer – Autogage Auto Meter 8K w/external shift light (new)
Wheels – 14X6 ralley
Tires – B F Goodrich P225-60R14
Hood – Fiberglass Unlimited flat (new)
Steering – Power
Brakes – Power front disc/rear drum
Line Lock – Enterprise (activated by horn ring)
Transmission – 727 automatic w/Red Eagle Friction and Kolene steels (new)
Transmission pan – Mancini steel deep sump w/extension (new)
Valve body – TCI Streetfighter (new)
Converter – Hughes 24-25 2600 stall (new)
Flex plate – 440 Source SFI (new)
Shifter – Hurst Pro-Matic 2
Shifter handle – PowerSHIFTER.com (new)
Differential – 8.75/3.23 SG
Axles – Moser LBP (new)
Rear suspension – Mancini HD leaf (new)
Front suspension – MP 1.080 torsion
Engine – 1968 RB 440 block .30 over
Crankshaft – OEM steel .10/.10 under
Pistons – Speed Pro L2355F30 forged (new)
Rods – 440 Source 5140 forged (new)
Balanced rotating assembly
Windage tray – MP (new/modified with more drain louvers)
Oil pump – Melling std (new)
Oil pan - OEM
Water pump and housing – 440 Source aluminum (new)
Lifters – 440 Source HD anti pump-up (new)
Timing chain – 440 Source double roller billet 3 bolt/3 way (new)
Heads – Edelbrock RPM aluminum/exh ported/matched (new)
Head bolts – ARP (new)
Camshaft – Lunati Voodoo hyd 268/276-.527/.547@1.6 (new)
Valvetrain – MP 1.6 roller rockers/Mancini chrome shaft (new)
Pushrods – MP HD 3/8 in. (new)
Distributor - OEM
Ignition – OEM/MSD 6AL w/5500 chip (located inside front battery)
Coil – MSD Blaster
Intake – Edelbrock CH-28 dual quad/dual plane
Carburator – Edelbrock 1405 2X600 cfm
Safety switch – Summit oil low pressure cutoff
Headers – Schumacher Tri-Y
Starter – MP mini (new)
S6-RB conversion - Schumacher (new)
Frame connectors – Mancini bolt-in (new)
Exhaust – Summit full 2-1/2 in. (new)
X-pipe – Summit (new)
Radiator – Summit 26 in. aluminum (new)
Plug wires – Taylor 8mm (new)
Fuel pump – OEM (new)
Fuel tank sending unit – Matt’s Classics 3/8 in. (new/modified to add 5/16” pickup)
Nitrous – NOS Super Shot x2
Holley Blue electric (activated by OEM rear defogger switch)
Holley fuel pressure regulator
Holley analog fuel pressure gauge
BigBlock 74 Swinger
Re: Sleeper mopars..what do you like. [Re: autoxcuda] #279669
12/06/09 09:44 AM
12/06/09 09:44 AM
Motor City
Shaker223 Offline
Shaker223  Offline
Motor City
I agree. And I like Shaker223's and cheapstreetdustr's cars too.
I want to see stock rims and non performance body No RR's, R/T's, GTX's
no shiny paint
no bright colors
Some road rash
weathered engine compartment
no aluminum rims, even dog dishes are that stealthy any more
bench seat
column automatic
no big tires
no hood scoops or performance hoods
4 doors are a plus!
mufflers that keep it as quiet as possible
74 and up smogger cars
Thanks for the nod!
Re: Sleeper mopars..what do you like. [Re: B1Fish540] #279670
12/06/09 11:51 AM
12/06/09 11:51 AM
Greenville, South Carolina
BBLM23 Offline
BBLM23  Offline
...the most unlikely race car.
Big difference between unlikely race car and sleeper.
Walter
1969 Dart Swinger w/ARC Pump Gas 493 B1/BS 10.18 at 130mph
Racing Pro in street trim.
1981 Aries ARC 548 B1 8.88 at 147mph (footbraking)
1996 Ram 2500 V10 16.52 at 80mph
1981 Reliant 400
Re: Sleeper mopars..what do you like. [Re: bb74swngr] #279671
12/06/09 03:11 PM
12/06/09 03:11 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Weight – 3450#
Radio – AM OEM
Steering – Power
Oil pan - OEM
Distributor - OEM
Coil – MSD Blaster
So....what's it run...that is if it's not top secret. If so I totally understand! That thing is awesome!
Re: Sleeper mopars..what do you like. [Re: Jeremiah] #279672
12/06/09 09:11 PM
12/06/09 09:11 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Big block a body....To med a sleeper has to be 'all in', quiet mufflers, unassumeing colors, stealth dual exhaust (my duster had a Dummy 318 single 2" tailpipe while the dual 2 1/2"s dumped out just behind the rear wheels completely hidden from view.
Second choice won't be popular but it is a Mopar...1990-94 Eagle Talon AWD, evo 16G turbo and some tuning tricks will put out 24+psi and will nail a 1.6 60' and run high 11's on street tires.
I used to think 67-69 Post A bodies were sleepers but if anything they are so obviously NOT sleepers.....much like the 327/375 Chevy II's anyone encountering one is once bitten-twice shy.
Still gotta Say Larry's pristine white Dart with the 414" cross ram is the car I wish I had as a Stablemate to my big blue Dodge.
WIZE
In Car:
Re: Sleeper mopars..what do you like. [Re: Streetwize] #279673
12/06/09 10:00 PM
12/06/09 10:00 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
Re: Sleeper mopars..what do you like. [Re: Jeremiah] #279674
12/07/09 09:39 AM
12/07/09 09:39 AM
Missouri
bb74swngr Offline
mopar addict
bb74swngr  Offline
mopar addict
Missouri
Weight – 3450#
Radio – AM OEM
Steering – Power
Oil pan - OEM
Distributor - OEM
Coil – MSD Blaster
Hi JD. I don't know what it runs, sorry. It's not real good in the traction department, just fun. The grandkids call it the grandpa car. It's fun taking it to the local car shows cause it is relatively stock looking even under the hood and yet can be a hand-full when playing.
BigBlock 74 Swinger
Re: Sleeper mopars..what do you like. [Re: bb74swngr] #279675
12/07/09 09:03 PM
12/07/09 09:03 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Don't laugh, this is a real sleeper, it's got the right stuff underneath to go, whoa and turn a hot lap. It does nice burnouts too!
Re: Sleeper mopars..what do you like. [Re: B1CUDA] #279676
12/08/09 03:27 PM
12/08/09 03:27 PM
Upland, California
Spode Offline
Spode  Offline
Upland, California
That guy (BOYD) had the sleeper thing going for a while. I lost to him off of Whittier blvd after he beat my buddies V8 350 vega. I knew I was alot faster than the Vega so it should be an easy win. Boyd smoked me. He always lifted the hood for you to look painted engine dual plane single snorkel stock air filter
A few weeks after I lost to him I saw him at OCIR pulling a low ten with the same car.
Re: Sleeper mopars..what do you like. #279677
12/08/09 05:05 PM
12/08/09 05:05 PM
Hampstead, MD.
Troublemaker427 Offline
Hampstead, MD.
Don't think you have to have the dash bar as long as you have a stock firewall. ..I think. maybe wrong.
This is correct.
Jody Aberts 1966 Fairlane 427 Troublemaker2 AA/NSS 1964 Galaxie 500XL 390-4spd. 1966 F-100 390-C6 1967 Plymouth VIP 383-TF 2003 Roadking
