Re: Sleeper mopars..what do you like.
[Re: bigtimeauto]
#279658
12/05/09 12:45 AM
12/05/09 12:45 AM
Wow, some people's definition of sleeper and mine are obviously different. Cowl hoods, big hoops and slicks scream "DRAG CAR" to me....
[Re: Airgrabber]
#279661
12/05/09 12:58 AM
12/05/09 12:58 AM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
mine are only true 10.5's in that pick i saw tubbed cars everywhere and i'm the one.....?
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: bigtimeauto]
#279663
12/05/09 01:22 AM
12/05/09 01:22 AM
Posts: 1,226 Cookeville
Chilort
Will Work For Mopars
Cookeville
I didn't go after you. I went after a car that's been attacked with a hole saw that has to have pistons replaced after every round.
[Re: B1KILLER]
#279665
12/05/09 11:23 AM
12/05/09 11:23 AM
Posts: 213 The Hand
KRiTiK
The Hand
Just saw this on the "best 60' on street radials " thread . 11.70's with a stock sounding Slant Six & 5" wide street tires , that's a sleeper !! http://www.youtube.com/watch?v=GMwcDlJGss0
Post deleted by Defbob
[Re: plasticfantastic]
#279667
12/05/09 01:33 PM
12/05/09 01:33 PM
[Re: B1Fish540]
#279668
12/05/09 11:34 PM
12/05/09 11:34 PM
Posts: 799 Missouri
bb74swngr
mopar addict
mopar addict
Missouri
Stock uncut body and interior (25K miles) KG2 Frosty Green Metallic w/V1W white vinyl top F3G6 green cloth and vinyl split bench seat w/center armrest Weight 3450# Carpeting Stockinteriors.com Jade Green cut pile (new) Air conditioning 134 Cruise control OEM Radio AM OEM Remote trunk release - OEM Tachometer Autogage Auto Meter 8K w/external shift light (new) Wheels 14X6 ralley Tires B F Goodrich P225-60R14 Hood Fiberglass Unlimited flat (new) Steering Power Brakes Power front disc/rear drum Line Lock Enterprise (activated by horn ring) Transmission 727 automatic w/Red Eagle Friction and Kolene steels (new) Transmission pan Mancini steel deep sump w/extension (new) Valve body TCI Streetfighter (new) Converter Hughes 24-25 2600 stall (new) Flex plate 440 Source SFI (new) Shifter Hurst Pro-Matic 2 Shifter handle PowerSHIFTER.com (new) Differential 8.75/3.23 SG Axles Moser LBP (new) Rear suspension Mancini HD leaf (new) Front suspension MP 1.080 torsion Engine 1968 RB 440 block .30 over Crankshaft OEM steel .10/.10 under Pistons Speed Pro L2355F30 forged (new) Rods 440 Source 5140 forged (new) Balanced rotating assembly Windage tray MP (new/modified with more drain louvers) Oil pump Melling std (new) Oil pan - OEM Water pump and housing 440 Source aluminum (new) Lifters 440 Source HD anti pump-up (new) Timing chain 440 Source double roller billet 3 bolt/3 way (new) Heads Edelbrock RPM aluminum/exh ported/matched (new) Head bolts ARP (new) Camshaft Lunati Voodoo hyd 268/276-.527/.547@1.6 (new) Valvetrain MP 1.6 roller rockers/Mancini chrome shaft (new) Pushrods MP HD 3/8 in. (new) Distributor - OEM Ignition OEM/MSD 6AL w/5500 chip (located inside front battery) Coil MSD Blaster Intake Edelbrock CH-28 dual quad/dual plane Carburator Edelbrock 1405 2X600 cfm Safety switch Summit oil low pressure cutoff Headers Schumacher Tri-Y Starter MP mini (new) S6-RB conversion - Schumacher (new) Frame connectors Mancini bolt-in (new) Exhaust Summit full 2-1/2 in. (new) X-pipe Summit (new) Radiator Summit 26 in. aluminum (new) Plug wires Taylor 8mm (new) Fuel pump OEM (new) Fuel tank sending unit Matts Classics 3/8 in. (new/modified to add 5/16 pickup) Nitrous NOS Super Shot x2 Holley Blue electric (activated by OEM rear defogger switch) Holley fuel pressure regulator Holley analog fuel pressure gauge
BigBlock 74 Swinger
[Re: autoxcuda]
#279669
12/06/09 09:44 AM
12/06/09 09:44 AM
Posts: 365 Motor City
Shaker223
Motor City
I agree. And I like Shaker223's and cheapstreetdustr's cars too.
I want to see stock rims and non performance body No RR's, R/T's, GTX's
no shiny paint no bright colors Some road rash weathered engine compartment no aluminum rims, even dog dishes are that stealthy any more bench seat column automatic no big tires no hood scoops or performance hoods 4 doors are a plus! mufflers that keep it as quiet as possible 74 and up smogger cars
Thanks for the nod!
[Re: bb74swngr]
#279671
12/06/09 03:11 PM
12/06/09 03:11 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
So....what's it run...that is if it's not top secret. If so I totally understand! That thing is awesome!
[Re: Jeremiah]
#279672
12/06/09 09:11 PM
12/06/09 09:11 PM
Posts: 9,876 Weddington, N.C.
Streetwize
Weddington, N.C.
Big block a body....To med a sleeper has to be 'all in', quiet mufflers, unassumeing colors, stealth dual exhaust (my duster had a Dummy 318 single 2" tailpipe while the dual 2 1/2"s dumped out just behind the rear wheels completely hidden from view. Second choice won't be popular but it is a Mopar...1990-94 Eagle Talon AWD, evo 16G turbo and some tuning tricks will put out 24+psi and will nail a 1.6 60' and run high 11's on street tires. I used to think 67-69 Post A bodies were sleepers but if anything they are so obviously NOT sleepers.....much like the 327/375 Chevy II's anyone encountering one is once bitten-twice shy. Still gotta Say Larry's pristine white Dart with the 414" cross ram is the car I wish I had as a Stablemate to my big blue Dodge.
