340 Pilot Bushing or Bearing??? #2791986
07/02/20 06:49 PM
07/02/20 06:49 PM
Michigan, USA
sixpackman Offline OP
Michigan, USA
Hello,
I need some help figuring out weather to use a Pilot bushing or a bearing? I've been told if I use a bearing I will need to cut the tip off trans input shaft??? Still can't understand that!!!
If my crank is an auto crank not a manual and my motor is already built, Is there a way to rem it out to except a bushing?
The reason for this post is to understand my options sense the motor builder didn't check or install it.
Thanks for any help you could give me.
Thanks again,
Scott
Re: 340 Pilot Bushing or Bearing??? [Re: sixpackman] #2791993
07/02/20 07:12 PM
07/02/20 07:12 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
The only time you NEED to chop the trans input shaft off is if the crank is not drilled deep enough for a pilot bushing.
IF thats the case you then have NO other option than a roller bearing in the back of the crank
Re: 340 Pilot Bushing or Bearing??? [Re: gtx6970] #2792001
07/02/20 07:27 PM
07/02/20 07:27 PM
Michigan, USA
Michigan, USA
I was thinking the same on chopping off the input shaft. The reason I'm asking is the paper that came with the bearing said you needed too?? And of coarse the engine builder kept the paperwork on it so I can't verify it.
It's a new crank to me sense my old one had welds and a crack in it. I prefer using the bearing but never have in the past and wanted a sanity check.
Thanks for the input.
Re: 340 Pilot Bushing or Bearing??? [Re: sixpackman] #2792002
07/02/20 07:29 PM
07/02/20 07:29 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Measure the depth of hole in the back of the crank before you cut anything
If it is deep enough you can still use the roller bearing with no issues if you so desire
Re: 340 Pilot Bushing or Bearing??? [Re: sixpackman] #2792144
07/02/20 11:58 PM
07/02/20 11:58 PM
CA
crackedback Online content
crackedback  Online Content
CA
If the opening in the crank is deep and wide enough to accept the input shaft pilot, no need to cut it.
You could probably get a grinder and open it up if need be.
Re: 340 Pilot Bushing or Bearing??? [Re: crackedback] #2792163
07/03/20 01:49 AM
07/03/20 01:49 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Probably OK with grinder, BUT ONLY if you need to increase a few thousands. Beyond that, I doubt you get a nice centered opening. That may lead to alignment issues with the mating parts.
Re: 340 Pilot Bushing or Bearing??? [Re: PhillyRag] #2792165
07/03/20 02:50 AM
07/03/20 02:50 AM
CA
CA
The pilot doesn't have to touch anything, there is no alignment issue when using the big bearing like the dakotas use. Hot dog down a hallway analogy here. Doesn't touch the walls at all.
The bushing/pilot isn't in play here at all unless the OP is asking about the smaller bearing style that aligns the pilot tip. I think they are talking about the type of pilot bearing that fit in the converter register and captures the smooth section just in front of the splines, not the pilot tip like the bushing does.
https://www.carid.com/1994-dodge-ram-transmission-parts/national-clutch-pilot-bearing-98317886.html
Re: 340 Pilot Bushing or Bearing??? [Re: crackedback] #2792169
07/03/20 05:58 AM
07/03/20 05:58 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
The first thing you do is measure the depth of the small hole in the crankshaft. It should be 1.750” deep to accept the input shaft. The correct diameter size hole for the original style pilot is .940. Anything less than that and an original style will not work. Most auto cranks of the era were only approximately .908. Some cranks had no hole at all. If it’s not deep cut it off or drill it deeper. Drilling is hard to do without a drill press. You last choice will be to cut the end of your input shaft off enough to clear and get the later style bearing that presses in the larger diameter hole when the converter hub normally goes. Good luck.
Re: 340 Pilot Bushing or Bearing??? [Re: crackedback] #2792513
07/04/20 03:49 AM
07/04/20 03:49 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Quote
So putting a steel shaft (input shaft end) into a bearing (with needle bearings); alignment isn't an issue. Since when?
Re: 340 Pilot Bushing or Bearing??? [Re: PhillyRag] #2792529
07/04/20 06:38 AM
07/04/20 06:38 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Ok. I need to update my post in a new one. I did not see the OP state this was a 340. All of the 340 steel cranks I have at my shop are all properly drilled for a pilot bearing from the factory. Most have a pilot bearing installed even though used behind and auto from the factory. Now, if you got a 318 or 273 steel crank instead, it may not have one. In that case, I hope you balanced it. Where did the crank come from?
Re: 340 Pilot Bushing or Bearing??? [Re: PhillyRag] #2792775
07/04/20 08:57 PM
07/04/20 08:57 PM
CA
CA
Quote
The big bearing uses the converter register, NOT, the OEM area where the smaller bronze bushing is installed. It's why you can cut off the end of the input shaft when using the BIG bearing... If the oem crank opening is wide enough and deep enough that section is now INSIGNIFICANT to alignment and operation! hot dog in a hallway... Also why you can grind it out if you choose to do so using the dakota bearing.
I used these register bearings on 360 cars all the time.
The red area is where the OEM bronze captures, blue where the Big dakota bearing captures.
Re: 340 Pilot Bushing or Bearing??? [Re: crackedback] #2792830
07/05/20 02:31 AM
07/05/20 02:31 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Quote
Quote
But the input shaft end is still inserted into the bearing. Again; alignment between those 2 parts not important?
Re: 340 Pilot Bushing or Bearing??? [Re: PhillyRag] #2792831
07/05/20 03:12 AM
07/05/20 03:12 AM
CA
CA
Quote
Quote
REALLY??? Way to parse the sentence and create an issue which was ANSWERED in said sentence... I'll try again and be done. I was talking about the alignment where the OEM bronze bushing would be which is NO LONGER present or needed. The alignment in the register bearing set up is just fine. Pick away if you like. Using the register style makes the OEM hole in the crank for aligning the tip a moot point. That's the hot dog down a hallway... carry on with whatever you like... LOL
Re: 340 Pilot Bushing or Bearing??? [Re: crackedback] #2792916
07/05/20 11:08 AM
07/05/20 11:08 AM
moparx Offline
moparx  Offline
a question i always wanted to ask, but never did,
can ALL cranks use the roller bearing, in other words, are ALL cranks machined for the torque converter snout ?
not trying to muddy the waters any more than they already are, just wondering.
beer
Re: 340 Pilot Bushing or Bearing??? [Re: moparx] #2792959
07/05/20 01:33 PM
07/05/20 01:33 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Yes. Some are a little tighter by a .0001 or so.
Re: 340 Pilot Bushing or Bearing??? [Re: fastmark] #2792962
07/05/20 01:39 PM
07/05/20 01:39 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
You forget about the early LA cranks,
Re: 340 Pilot Bushing or Bearing??? [Re: moparx] #2792964
07/05/20 01:50 PM
07/05/20 01:50 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
beer
As far as I know, Yes.
the big register is originally for torque conv alignment so to speak
it wasnt till maybe the 80s is when the roller bearing showed up for manual trans use
Re: 340 Pilot Bushing or Bearing??? [Re: gtx6970] #2793347
07/06/20 11:49 AM
07/06/20 11:49 AM
moparx Offline
moparx  Offline
thanks for the responses guys ! i now know the answer to my question. up
beer
