air grabber rivets #2785139
06/13/20 09:03 PM
06/13/20 09:03 PM
taunton, mass. 02780
moparthunder70 Offline OP
Has anyone had any experience removing air grabber rivets from the hood box ? I assume you would drill a hole in the middle of the rivet to remove it...I'm wondering if I should use a 1/8 or 3/16 bit..Logic would tell me not to use a bit bigger than the shank of the rivet ? I have to remove the air grabber to detail it and the underside of the hood....
Re: air grabber rivets [Re: moparthunder70] #2785287
06/14/20 10:31 AM
06/14/20 10:31 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I have no idea but if it was me I would start small then go up to the size needed.
Re: air grabber rivets [Re: moparthunder70] #2785298
06/14/20 10:54 AM
06/14/20 10:54 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
If it were me, I would take a small die grinder ( think dremel tool here ) and grind the head away. Pull the box off the remains then work the shank out.
if you drill them out the remains end up down inside the bracing of the hood causing rattles
BUT, the best I remember the shank size is 3/16" if that helps
Re: air grabber rivets [Re: gtx6970] #2785321
06/14/20 11:22 AM
06/14/20 11:22 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
If you drill, use a stop on the bit; a length of vacuum hose works well.
Re: air grabber rivets [Re: topside] #2785367
06/14/20 12:36 PM
06/14/20 12:36 PM
CA
crackedback Offline
crackedback  Offline
CA
grinding the center also removes the risk of a rivet head spinning and breaking off a tab.
Re: air grabber rivets [Re: crackedback] #2785634
06/15/20 10:31 AM
06/15/20 10:31 AM
None
71rm23 Offline
71rm23  Offline
None
Agree and then use a small drill bit (1/8 least) to knock the stem loose. Do this all the time on airplanes and usually, it's a #30 or #40 drill bit
Re: air grabber rivets [Re: 71rm23] #2785888
06/15/20 11:01 PM
06/15/20 11:01 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Most 1/8" rivets are drilled with a #30 bit, they make tools to drill out rivets. look at the yardstore.com for the tool to keep the drill centered.
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: air grabber rivets [Re: astjp2] #2785924
06/16/20 08:04 AM
06/16/20 08:04 AM
MD
floyd Offline
floyd  Offline
MD
Interesting- Google “rivet removal tool. Here a couple videos that shows how they work. Pretty slick.
https://m.youtube.com/watch?v=4SPevpRAruU
https://vintagetrailersupply.com/rivet-removal-tool-vts-497/
Re: air grabber rivets [Re: gtx6970] #2786084
06/16/20 05:14 PM
06/16/20 05:14 PM
sounds like the best solution..thanks so much...been off the site for a while so didn't respond right away...air grabber is original...would hate to break off the tabs due to insufficient knowledge...appreciate all the suggestions...thanks a bunch..
