Has anyone had any experience removing air grabber rivets from the hood box ? I assume you would drill a hole in the middle of the rivet to remove it...I'm wondering if I should use a 1/8 or 3/16 bit..Logic would tell me not to use a bit bigger than the shank of the rivet ? I have to remove the air grabber to detail it and the underside of the hood....
