If it were me, I would take a small die grinder ( think dremel tool here ) and grind the head away. Pull the box off the remains then work the shank out.
if you drill them out the remains end up down inside the bracing of the hood causing rattles
BUT, the best I remember the shank size is 3/16" if that helps
