Re: air grabber rivets
[Re: crackedback]
#2785634
06/15/20 10:31 AM
06/15/20 10:31 AM
Posts: 2,592 None
71rm23
None
grinding the center also removes the risk of a rivet head spinning and breaking off a tab. Agree and then use a small drill bit (1/8 least) to knock the stem loose. Do this all the time on airplanes and usually, it's a #30 or #40 drill bit
[Re: 71rm23]
#2785888
06/15/20 11:01 PM
06/15/20 11:01 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Most 1/8" rivets are drilled with a #30 bit, they make tools to drill out rivets. look at the yardstore.com for the tool to keep the drill centered.
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: gtx6970]
#2786084
06/16/20 05:14 PM
06/16/20 05:14 PM
Posts: 80 taunton, mass. 02780
moparthunder70
sounds like the best solution..thanks so much...been off the site for a while so didn't respond right away...air grabber is original...would hate to break off the tabs due to insufficient knowledge...appreciate all the suggestions...thanks a bunch..
