Re: Mystery in oil pan???
[Re: road]
#2780859
06/02/20 07:05 PM
06/02/20 07:05 PM
Posts: 20,662 in a cattle trailer down by th...
Guitar Jones
That is the oil metering disc from a hydraulic lifter.
[Re: Guitar Jones]
#2780880
06/02/20 08:11 PM
06/02/20 08:11 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
That is the oil metering disc from a hydraulic lifter. Yep, but HOW? I've had a lifter explode when a pushrod got shoved down after a timing chain snapped and valve tried to fornicate my piston. But it left a lot more metal all over.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: road]
#2780936
06/03/20 12:04 AM
06/03/20 12:04 AM
Posts: 1,908 Nebraska
4406bbl
Nebraska
Can anyone identify this small mystery item found in the bottom of my oil pan. 340 4 barrel
Thanks It could be from a lifter, but kind of looks like that pattern those round casting marks in the lifter valley have. Maybe from the original casting core box?? Just thinking out loud.
[Re: Dave_J]
#2780951
06/03/20 03:33 AM
06/03/20 03:33 AM
Guitar Jones
That is the oil metering disc from a hydraulic lifter. Yep, but HOW? I've had a lifter explode when a pushrod got shoved down after a timing chain snapped and valve tried to fornicate my piston. But it left a lot more metal all over. Well we really don't have much information to go on. All we know is it's a 340. Why is the oil pan off? Is there other debris in the pan and this is the only piece the OP doesn't know? Was there a failure? Prior rebuild or repair? The last 340 was produced in '73 so chances are unless it's been stored somewhere for the last 30+ years it's had some work done to it.
[Re: road]
#2780996
06/03/20 10:02 AM
06/03/20 10:02 AM
Guitar Jones
Take an old lifter apart if you don't believe me. I don't know how or why it was in your oil pan but it's an oil metering disc from a lifter without a doubt.
