Mystery in oil pan??? #2780842
06/02/20 06:30 PM
06/02/20 06:30 PM
Omaha
road Offline OP
road  Offline OP
Omaha
Can anyone identify this small mystery item found in the bottom of my oil pan. 340 4 barrel
Re: Mystery in oil pan??? [Re: road] #2780843
06/02/20 06:33 PM
06/02/20 06:33 PM
USA
Suregrip391 Offline
Suregrip391  Offline
USA
What’s it made of? Looks like a button from a sleeve or shirt.
Re: Mystery in oil pan??? [Re: road] #2780844
06/02/20 06:34 PM
06/02/20 06:34 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
iagree Looks like a button? What's it made of? shruggy
Re: Mystery in oil pan??? [Re: stumpy] #2780847
06/02/20 06:46 PM
06/02/20 06:46 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I'm thinking button as well.
Found a leaf in one, in perfect condition, about 35 years ago.
Re: Mystery in oil pan??? [Re: road] #2780859
06/02/20 07:05 PM
06/02/20 07:05 PM
Guitar Jones Offline
That is the oil metering disc from a hydraulic lifter.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Mystery in oil pan??? [Re: Guitar Jones] #2780880
06/02/20 08:11 PM
06/02/20 08:11 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
Yep, but HOW? I've had a lifter explode when a pushrod got shoved down after a timing chain snapped and valve tried to fornicate my piston. But it left a lot more metal all over.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: Mystery in oil pan??? [Re: road] #2780936
06/03/20 12:04 AM
06/03/20 12:04 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
It could be from a lifter, but kind of looks like that pattern those round casting marks in the lifter valley have. Maybe from the original casting core box?? Just thinking out loud.
Re: Mystery in oil pan??? [Re: Dave_J] #2780951
06/03/20 03:33 AM
06/03/20 03:33 AM
Well we really don't have much information to go on. All we know is it's a 340. Why is the oil pan off? Is there other debris in the pan and this is the only piece the OP doesn't know? Was there a failure? Prior rebuild or repair? The last 340 was produced in '73 so chances are unless it's been stored somewhere for the last 30+ years it's had some work done to it.
Re: Mystery in oil pan??? [Re: Guitar Jones] #2780969
06/03/20 08:24 AM
06/03/20 08:24 AM
Omaha
road Offline OP
road  Offline OP
Omaha
Wow Thanks so far.
It was the only thing in the pan. It is metal, thin and sturdy, I was changing the cam. Motor had around 1200 miles since rebuild. Took the pan off to improve chances of good gasket seal. Also changed lifters and all old were complete. Don't know the prior history of motor. Took a picture of the other side of the piece. What looks like a ring around the first picture and a circle on the second and not raised but look like this piece was a part of something.
Thanks all.
Re: Mystery in oil pan??? [Re: road] #2780996
06/03/20 10:02 AM
06/03/20 10:02 AM
Take an old lifter apart if you don't believe me. I don't know how or why it was in your oil pan but it's an oil metering disc from a lifter without a doubt.
Re: Mystery in oil pan??? [Re: Guitar Jones] #2781097
06/03/20 02:59 PM
06/03/20 02:59 PM
Omaha
road Offline OP
road  Offline OP
Omaha
Guitar Jones is correct. Just took a lifter apart and sure enough.
Re: Mystery in oil pan??? [Re: road] #2781170
06/03/20 06:31 PM
06/03/20 06:31 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Years ago I was converting my 72 Swing from /6 to 360. Bought a 79 Cordoba as the donor. Pulled the engine to inspect and regasket it, found an extra connecting rod nut in the crankcase. Pretty sure this was an untouched engine (date codes on the bearings coincided) near as I can figure when they were assembling the engine someone dropped the nut inside and just grabbed another rather than find it and fish it out. Good old 70's QA. I would probably think your part is there from the prior work and someone was lazy.
