Re: Mystery in oil pan???
[Re: road]
#2780859
06/02/20 07:05 PM
06/02/20 07:05 PM
Posts: 20,622 in a cattle trailer down by th...
Guitar Jones
That is the oil metering disc from a hydraulic lifter.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#2780880
06/02/20 08:11 PM
06/02/20 08:11 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
That is the oil metering disc from a hydraulic lifter. Yep, but HOW? I've had a lifter explode when a pushrod got shoved down after a timing chain snapped and valve tried to fornicate my piston. But it left a lot more metal all over.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: road]
#2780936
06/03/20 12:04 AM
06/03/20 12:04 AM
Posts: 1,908 Nebraska
4406bbl
Nebraska
Can anyone identify this small mystery item found in the bottom of my oil pan. 340 4 barrel
Thanks It could be from a lifter, but kind of looks like that pattern those round casting marks in the lifter valley have. Maybe from the original casting core box?? Just thinking out loud.
[Re: Dave_J]
#2780951
06/03/20 03:33 AM
06/03/20 03:33 AM
Guitar Jones
That is the oil metering disc from a hydraulic lifter. Yep, but HOW? I've had a lifter explode when a pushrod got shoved down after a timing chain snapped and valve tried to fornicate my piston. But it left a lot more metal all over. Well we really don't have much information to go on. All we know is it's a 340. Why is the oil pan off? Is there other debris in the pan and this is the only piece the OP doesn't know? Was there a failure? Prior rebuild or repair? The last 340 was produced in '73 so chances are unless it's been stored somewhere for the last 30+ years it's had some work done to it.
[Re: road]
#2780996
06/03/20 10:02 AM
06/03/20 10:02 AM
Guitar Jones
Take an old lifter apart if you don't believe me. I don't know how or why it was in your oil pan but it's an oil metering disc from a lifter without a doubt.
