Page 5 of 5 1 2 3 4 5
Re: Anything wrong with a Fram PH8a for racecar? [Re: CSK] #2778778
05/27/20 03:59 PM
05/27/20 03:59 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Originally Posted by csk
Originally Posted by Cab_Burge
You don't remember all the hype on T.V. in the late 1950 and early 1960 selling those add on oil filters that used T.P rolls instead of using standard oil filters?
I wish I could remember the name of that company, I never used them either tsk
Man I must be getting old, HUH DOC grin
Frantz was one.
That sounds correct, THANKS up
Amsoil Sold the same thing , not sure if they still do.
No they do not. In fact if you cut one of their filters open they are identical to a wix racing filter or napa gould.
JAKES AUTOMOTIVE
Re: Anything wrong with a Fram PH8a for racecar? [Re: CSK] #2778784
05/27/20 04:17 PM
05/27/20 04:17 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
Frantz was one.
This is not a full flow system any more.
The Franz and Amsoil are now a 'Bypass' oiling system where a small amount of oil is tee'ed off the main filtered oil feed to go thru the Toilet Paper. It can not flow enough to supply the engine in full flow. The Bypass'ed oil is filtered down to 2 microns and then just dumped back into the oil pan.
A Fram PH8 and Wix 51515 are about 20 microns. Tests have said that anything above 5 microns is bad for long term use.
The Fram PH8A, HP1 and Wix 51515R are about 40 microns and the idea is that you will dump the oil after so many races, RACES not street miles.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: Anything wrong with a Fram PH8a for racecar? [Re: Dave_J] #2779509
05/29/20 03:39 PM
05/29/20 03:39 PM
tboomer Online work
tboomer  Online Work
Ok...So my wife picked up a NAPA Gold for my 64 Dodge and one for my 95 Ram 1500 with a 5.9 magnum. The total for the pair was 17.00 without sales tax. Fram filters sell for a lot less at the farm store. I always run Wix or Napa Gold on the drag car but the old Ram I usually put a cheap farm store filter on it. That truck has almost 190000 miles on it and no problem with oil pressure... wave
Re: Anything wrong with a Fram PH8a for racecar? [Re: tboomer] #2779515
05/29/20 03:54 PM
05/29/20 03:54 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I’m good for awhile
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Anything wrong with a Fram PH8a for racecar? [Re: tboomer] #2779519
05/29/20 04:04 PM
05/29/20 04:04 PM
Guitar Jones Offline
I think most off brand filters are made better than the Fram. I would use anything else than a Fram.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Anything wrong with a Fram PH8a for racecar? [Re: Guitar Jones] #2779524
05/29/20 04:34 PM
05/29/20 04:34 PM
tboomer Online work
tboomer  Online Work
Thanks guys..Got enough filters on hand John??
Re: Anything wrong with a Fram PH8a for racecar? [Re: Guitar Jones] #2779525
05/29/20 04:35 PM
05/29/20 04:35 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Menards has PH8A for $3.45 each.
Re: Anything wrong with a Fram PH8a for racecar? [Re: mopars4ever] #2779530
05/29/20 04:50 PM
05/29/20 04:50 PM
Maybe Grizzly will go buy a gross of them!
Re: Anything wrong with a Fram PH8a for racecar? [Re: Guitar Jones] #2779538
05/29/20 05:17 PM
05/29/20 05:17 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
[spoiler][/spoiler]
So BANJOnes .... anything else ??!! ... even considering mopXs suggestion of Dollar Tree TP ?
Re: Anything wrong with a Fram PH8a for racecar? [Re: Guitar Jones] #2779539
05/29/20 05:20 PM
05/29/20 05:20 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
No GRIZZZ cleaned out the local Dollar General! whistling
Re: Anything wrong with a Fram PH8a for racecar? [Re: tboomer] #2779541
05/29/20 05:21 PM
05/29/20 05:21 PM
PA.
"Little"John
"Little"John
PA.
Ya I’m good. It’s nice getting a heads up call and getting them at 40-50% off during their biannual sale. She’s a real cutie and great at looking up and getting me parts for my 50 year old junk cars.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Anything wrong with a Fram PH8a for racecar? [Re: dOc !] #2779561
05/29/20 06:25 PM
05/29/20 06:25 PM
Originally Posted by Doc Fiberglass
[spoiler][/spoiler]
No TP is too far scarce these days to even consider that! I remember seeing those ads as a kid and couldn't understand how that would not come apart and clog up the sump. I mean hell even my finger breaks through that stuff once in awhile. laugh2
Re: Anything wrong with a Fram PH8a for racecar? [Re: Guitar Jones] #2791210
06/30/20 08:59 PM
06/30/20 08:59 PM
N.W. INDIANA
moparjohn Offline
moparjohn  Offline
N.W. INDIANA
I have read this oil filter post from the start.
There were a couple of replies about the K&N filters.
I had been using the HP-3001 with no problems.
So after reading this I decided to install a WIX filter and see if there was an oil pressure increase?
I didn't notice much of a change in pressure.
But I decided to cut the filter open and see what it looked like inside.
The part that shows in my picture is where it was distorted a bit.
From those in the know what are your thoughts on the distortion?
Thanks! MJ
Re: Anything wrong with a Fram PH8a for racecar? [Re: moparjohn] #2791232
06/30/20 09:22 PM
06/30/20 09:22 PM
I don't think that is a big deal. Looks like they had room for more pleats though.
Re: Anything wrong with a Fram PH8a for racecar? [Re: moparjohn] #2791260
06/30/20 10:19 PM
06/30/20 10:19 PM
I've cut a bunch of different brand oil filters apart for inspections, I don't remember seeing that in any of the Wix filters I've inspected work
I have seen that in other brands, maybe they are in a hurry and don't do very good quality control work
Re: Anything wrong with a Fram PH8a for racecar? [Re: Cab_Burge] #2791390
07/01/20 09:54 AM
07/01/20 09:54 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
While I am sure they are adequate, the reviews of K&N oil filters I have seen, compared to others have not been that great.
Re: Anything wrong with a Fram PH8a for racecar? [Re: 340Cuda] #2791476
07/01/20 12:20 PM
07/01/20 12:20 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I have a new , from the early 90's HP-1 in my cabinet if anyone wants to buy it --just one, also have 1 direct connection filter in there too and several wix both street and strip versions
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
