833 Questions #2779476
05/29/20 01:59 PM
05/29/20 01:59 PM
stratford,ontario,canada
JD340 Offline OP
JD340  Offline OP
Will a Hurst Competition Plus shifter and rods from a normal B body 833 work on an 833 OD truck trans? Would I need to reuse the OD 3-4 rod or will the Comp one work as is? Any help appreciated.
Nothing to see here. Carry on.
Re: 833 Questions [Re: JD340] #2779480
05/29/20 02:13 PM
05/29/20 02:13 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
The shifter will work as long as it has the same hair pin setup as factory.
Putting an OD in is a little more involved with modifying the rods and transmission levers.
If you know how to weld it's easy, it's a bit of a pain though.
Are you putting an OD in a B body or putting the shifter in a truck with OD?
Mo' Farts
Moderated by "tbagger".
Re: 833 Questions [Re: Grizzly] #2779481
05/29/20 02:20 PM
05/29/20 02:20 PM
JD340 Offline OP
JD340  Offline OP
Hoping to use the shifter in my truck. My factory shifter is worn and sloppy, I figured an upgrade to the comp plus would tighten things up considerably. PLUS, it comes with the pistol grip shifter I've been wanting to add as well!
Re: 833 Questions [Re: JD340] #2779500
05/29/20 03:11 PM
05/29/20 03:11 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
It will work but you may need to make the 3-4 rod longer shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: 833 Questions [Re: fourgearsavoy] #2779501
05/29/20 03:16 PM
05/29/20 03:16 PM
JD340 Offline OP
JD340  Offline OP
Gus beer
Are you talking adjustment wise, or actually making the rod longer? Could I use the original 3-4 rod instead?
Re: 833 Questions [Re: JD340] #2779630
05/29/20 09:41 PM
05/29/20 09:41 PM
Rittman Ohio
Rittman Ohio
If you use the B body shifter mounting pad you wont have to do any thing at all. But if you used the raised bracket for the truck trans you may need to lengthen one or more rods if you run out of threads.
Gus beer
64 Plymouth Savoy
Dana 60
Re: 833 Questions [Re: fourgearsavoy] #2779657
05/30/20 12:56 AM
05/30/20 12:56 AM
Salem
Grizzly Offline
Grizzly  Offline
Salem
I looked up a picture of the shifter and if I got the right image, it sure looks alot like a stock shifter? shruggy
This is just me, but I would just re-build and re-grease the truck shifter (it is a Hurst shifter), cut the end off, weld on the pistol grip, and modify for shorter throws.
That's what I did to shorten the shifts on my current 833od in an E-Body and it's awesome. wink The throws are about 4 to 5 inches long, maybe less.........haven't driven it since last year. work
Mo' Farts
Re: 833 Questions [Re: Grizzly] #2779678
05/30/20 08:43 AM
05/30/20 08:43 AM
VA
dragon slayer Offline
VA
What year is your B body? Pistol grip was 70 and that is not a match up to the truck. The OD Truck shifter was like the 68-69 B body shifter, with the addition of a grease fitting.
You could always rebuild the truck shifter. Or move the levers over from your truck shifter to your comp shifter. Not hard to do.
Compare your levers to see the difference.
Re: 833 Questions [Re: dragon slayer] #2780087
05/31/20 03:07 PM
05/31/20 03:07 PM
JD340 Offline OP
JD340  Offline OP
Thanks everyone, you've given some great advice as usual. Once new parts are on hand, I'll compare and make any necessary changes. up
