Page 5 of 10 1 2 3 4 5 6 7 9 10
Re: TH400 to RB in 69 b body info [Re: Clanton] #2774211
05/13/20 01:44 PM
05/13/20 01:44 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I need to mount everything and check the starter to flex plat fit.
Re: TH400 to RB in 69 b body info [Re: Clanton] #2774221
05/13/20 02:10 PM
05/13/20 02:10 PM
AndyF Offline
AndyF  Offline
Looks good so far. Nice beefy looking part. Good luck with the project, I'm sure you'll run into a bunch of little things that need to be "adjusted".
Re: TH400 to RB in 69 b body info [Re: AndyF] #2774516
05/14/20 01:51 PM
05/14/20 01:51 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Check the depth going into the adapter with the converter, mine only had .030 . I took .100 off
The adapter so the converter had more clearance . I checked it with some play-do
....BAD A$$ STREET CAR.....
Re: TH400 to RB in 69 b body info [Re: n20mstr] #2774556
05/14/20 03:35 PM
05/14/20 03:35 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
So far I have .032 off center
Re: TH400 to RB in 69 b body info [Re: n20mstr] #2774561
05/14/20 03:40 PM
05/14/20 03:40 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I will talk to you about this later today.I have no base measurements to go by.
Re: TH400 to RB in 69 b body info [Re: Clanton] #2774688
05/14/20 10:44 PM
05/14/20 10:44 PM
Time for some RobbMC adjustable offset bell housing dowels to correct this twocents scope
I'm thinking less than .007 total run out like we shoot for on stick shift scatter shields scope up
Re: TH400 to RB in 69 b body info [Re: Cab_Burge] #2774732
05/15/20 08:25 AM
05/15/20 08:25 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I think the biggest offset I can get is .015 and to pull the 1's in the engine all I have is some visegrips so I hope that works.Moving the bell .015"I don't think is going to effect the starter much.
Re: TH400 to RB in 69 b body info [Re: Clanton] #2774766
05/15/20 09:51 AM
05/15/20 09:51 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
.032 off center? - I think you better double check your measurements again - I have never seen one out that far
How are you centering your dial indicator on the Crank??
Re: TH400 to RB in 69 b body info [Re: DoubleD] #2774788
05/15/20 11:18 AM
05/15/20 11:18 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I didn't.I measured for the low spot and 0 the dial.I still have it set in place to measure today but I am confident it is reading okay in the small steps I am turning it and the angle is small.
Re: TH400 to RB in 69 b body info [Re: DoubleD] #2774790
05/15/20 11:19 AM
05/15/20 11:19 AM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Doesn't need centering on the crank
Re: TH400 to RB in 69 b body info [Re: Clanton] #2774793
05/15/20 11:25 AM
05/15/20 11:25 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I did check the adapter and flex plate 1st,put on the bell
Re: TH400 to RB in 69 b body info [Re: n20mstr] #2774795
05/15/20 11:29 AM
05/15/20 11:29 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
When I get that far and have the converter I will lay it against the flex plate and check it.Thank youThe I.D. was 1.704
Re: TH400 to RB in 69 b body info [Re: Clanton] #2774806
05/15/20 11:57 AM
05/15/20 11:57 AM
Sidney,Ohio
challenger1320 Offline
Sidney,Ohio
You have account for indicator sag when doing it the way you are. When you are on top it is falling away and when you are on the bottom it is falling toward. It won't be .032 but there is some.
Re: TH400 to RB in 69 b body info [Re: Clanton] #2774832
05/15/20 12:49 PM
05/15/20 12:49 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I checked again and the same I just measured more often
Re: TH400 to RB in 69 b body info [Re: Clanton] #2774833
05/15/20 12:51 PM
05/15/20 12:51 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
TDC is .000 and BDC is .035"
Re: TH400 to RB in 69 b body info [Re: Clanton] #2774881
05/15/20 03:24 PM
05/15/20 03:24 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
OK - I got you now- divide .035 by 2 and your number is .0175 - a .015 offset dowel will put at .002 which is considered perfect for high RPM - if you get between .05 and .010 you are in the good range for what you are running
You need to do 4 points every 90 degrees so you know what what way it is shifted
Re: TH400 to RB in 69 b body info [Re: DoubleD] #2774909
05/15/20 04:53 PM
05/15/20 04:53 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thank you for your insight .I looked at RobMc dowels and will give him a call ty!
Re: TH400 to RB in 69 b body info [Re: Clanton] #2774911
05/15/20 04:59 PM
05/15/20 04:59 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
So with .014 offset I will have to adjust all the bolt holes on the bell.What say you?
Re: TH400 to RB in 69 b body info [Re: Clanton] #2774948
05/15/20 07:17 PM
05/15/20 07:17 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Hey Mike if you need a rock solid dial indicator mount that bolts to the crank flange you can use mine. I had it made strong so I could get my bell dialed in without the indicator moving around. Let me know and I can meet you somewhere and get it to you.
Gus beer
64 Plymouth Savoy
Dana 60
Re: TH400 to RB in 69 b body info [Re: fourgearsavoy] #2774967
05/15/20 08:20 PM
05/15/20 08:20 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
What a great offer Thank you.I think I am within .003 soI have had enough for now and will move on to getting a converter,driveshaft n yokeThe solid mount sounds interesting if you have a pic?
Gus beer
