who makes 1/2-20 Titanium wheel studs?
#1362599
01/01/13 04:28 AM
01/01/13 04:28 AM
fullmetaljacket
Just looking if there is a company that makes them in this spec. 6AL4V Titanium screw in 1/2" x 20 thread 2" or 3" long.
I know of the Mark Williams 5/8 studs, but those are too big for my application.
Re: who makes 1/2-20 Titanium wheel studs?
[Re: fullmetaljacket]
#1362600
01/01/13 03:29 PM
01/01/13 03:29 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I think I can help,,,check yur PMs... Also keep in mind, some drag racing organizations banned Ti studs a few years ago.,...I dont know what you need them for,,,but just an FYI.
RIP Monte Smith
#2773849
05/12/20 11:54 AM
05/12/20 11:54 AM
Titanium Metals
Titanium Metals
I know of the Mark Williams 5/8 studs, but those are too big for my application. Titan supplies Titanium Ti6Al4V Grade 5 fasteners to racing car and bikes.
[Re: sr4440]
#2773875
05/12/20 01:08 PM
05/12/20 01:08 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
As SR said you can get what you need here https://www.ti64.com/Been using their stuff for a number of years
#2773881
05/12/20 01:24 PM
05/12/20 01:24 PM
Posts: 25,802 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Comp.
Why would drag racing organizations ban Ti studs? Are they too brittle to run on the wheels. The ban came after the Antron Brown incident where the lugs failed and the flying wheel killed somebody. Probably the fault of over-torqueing but you know the NHRA....always overreact. From section 17.7 of the 2010 NHRA Rulebook: Front wheels meeting SFI Spec 15.2 mandatory. Beadlock 16-inch rear wheels meeting SFI Spec 15.3 mandatory; inner bead minimum 14 3/4 inches (+/- 1/8-inch). Wire wheels prohibited. Rearwheel discs or covers prohibited. Wheels must conform to applicable tire-manufacturer requirements. Minimum diameter on front wheels 17 inches. Any modifications and/or lightening prohibited. Titanium wheel studs prohibited.
#2773899
05/12/20 02:24 PM
05/12/20 02:24 PM
Posts: 4,206 New York
polyspheric
New York
Considering the tiny weight loss and the small polar moment, the loss of strength makes this a risk with minimal return.
Boffin Emeritus
[Re: Jeremiah]
#2773908
05/12/20 02:52 PM
05/12/20 02:52 PM
Posts: 4,675 Wichita
GY3
Wichita
You guys need to stop showing me this stuff lol. SAME!
[Re: polyspheric]
#2773909
05/12/20 03:04 PM
05/12/20 03:04 PM
Posts: 11,570 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I'm assuming this is for the rear. Anything going fast enough to benefit from Ti should have 5/8 stuff in it anyway. I like to use it on anything with a spool and/or sticky tires.
I also don't believe the Ti studs are as strong as steel. So if 1/2" steel stuff is marginal to begin with, going to Ti is asking for trouble.
#2773972
05/12/20 07:56 PM
05/12/20 07:56 PM
polyspheric
New York
Even those who should know better trip over laws of physics. Famous test of 3 (then current) Porsche models (1973?). Brock Yates notices the press handout says "the wheel lugs are aluminum". Thinking this is a typo, he asks the PR person "WTH?", who answers "Zey are lighter!".
At that point in time, writers dare not mention the fact that trailing throttle oversteer* was still killing Porsche owners.... * enter a turn too fast, back off the throttle, causes fatal oversteer, car loops
Boffin Emeritus
[Re: CMcAllister]
#2773996
05/12/20 09:21 PM
05/12/20 09:21 PM
Posts: 22,696 Bitopia
jcc
Bitopia
I also don't believe the Ti studs are as strong as steel. So if 1/2" steel stuff is marginal to begin with, going to Ti is asking for trouble. Titanium has grades ($$$) stronger then many steels, the real issue I believe is fatigue, its fatigue property is somewhere between Alum and steel, ie it has a finite limited cyclic useful life. I can't see a useful application for 1/2" Ti studs of any grade.
[Re: jcc]
#2774017
05/12/20 10:30 PM
05/12/20 10:30 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
If it's a weight issue, I would think there are many other places to save that pound or so cheaper and without hurting reliability. If it's for strength, go to 5/8" stuff.
[Re: CMcAllister]
#2774180
05/13/20 12:42 PM
05/13/20 12:42 PM
John_Kunkel
Rio Linda, CA
The driver's weight will vary from day-to-day more than the weight savings of Ti lugs.
[Re: John_Kunkel]
#2774258
05/13/20 04:15 PM
05/13/20 04:15 PM
Posts: 7,490 Minnesota
Hemi_Joel
Minnesota
It all adds up. Every once counts
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
