Page 1 of 3 1 2 3
who makes 1/2-20 Titanium wheel studs? #1362599
01/01/13 04:28 AM
01/01/13 04:28 AM
fullmetaljacket Offline OP
Just looking if there is a company that makes them in this spec.
6AL4V Titanium screw in 1/2" x 20 thread 2" or 3" long.
I know of the Mark Williams 5/8 studs, but those are too big for my application.
Re: who makes 1/2-20 Titanium wheel studs? [Re: fullmetaljacket] #1362600
01/01/13 03:29 PM
01/01/13 03:29 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
I think I can help,,,check yur PMs...
Also keep in mind, some drag racing organizations banned Ti studs a few years ago.,...I dont know what you need them for,,,but just an FYI.
RIP Monte Smith
Re: who makes 1/2-20 Titanium wheel studs? [Re: fullmetaljacket] #1362601
01/01/13 03:31 PM
01/01/13 03:31 PM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
Try these guys. They would probably be able to help you.
http://www.tricktitanium.com/titanium-hardware
John
Re: who makes 1/2-20 Titanium wheel studs? [Re: DusterW2] #1362602
01/01/13 03:33 PM
01/01/13 03:33 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
You might hit up Rick with the F.A.S.T Firebird...word is that basically his whole car is titanium...including his exhaust system, BTW...
If you can't handle the truth, you're living a lie.......
Re: who makes 1/2-20 Titanium wheel studs? [Re: Big Squeeze] #1362603
01/01/13 06:01 PM
01/01/13 06:01 PM
Not surprised on that tricked Bird. Heard he also went F1 on us and had his front rotors made out of carbon fiber.
Re: who makes 1/2-20 Titanium wheel studs? [Re: CompWedgeEngines] #1362604
01/01/13 06:02 PM
01/01/13 06:02 PM
Comp.
Why would drag racing organizations ban Ti studs?
Are they too brittle to run on the wheels.
Re: who makes 1/2-20 Titanium wheel studs? [Re: fullmetaljacket] #2773849
05/12/20 11:54 AM
05/12/20 11:54 AM
Titanium Metals
Titanium Metals
Titan supplies Titanium Ti6Al4V Grade 5 fasteners to racing car and bikes.
Re: who makes 1/2-20 Titanium wheel studs? [Re: fullmetaljacket] #2773864
05/12/20 12:36 PM
05/12/20 12:36 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Ti64 has them. Chris the owner is a good guy, did a bunch of work for him.
https://www.ti64.com/titanium-wheel-centers-studs-beadlocks-s/110818.htm
Joe
Without Data, you’re just another guy with an opinion.
Re: who makes 1/2-20 Titanium wheel studs? [Re: sr4440] #2773875
05/12/20 01:08 PM
05/12/20 01:08 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
As SR said you can get what you need here
Been using their stuff for a number of years
Re: who makes 1/2-20 Titanium wheel studs? [Re: fullmetaljacket] #2773881
05/12/20 01:24 PM
05/12/20 01:24 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Comp.
The ban came after the Antron Brown incident where the lugs failed and the flying wheel killed somebody. Probably the fault of over-torqueing but you know the NHRA....always overreact.
From section 17.7 of the 2010 NHRA Rulebook:
Front wheels meeting SFI Spec 15.2 mandatory. Beadlock 16-inch
rear wheels meeting SFI Spec 15.3 mandatory; inner bead
minimum 14 3/4 inches (+/- 1/8-inch). Wire wheels prohibited. Rearwheel
discs or covers prohibited. Wheels must conform to
applicable tire-manufacturer requirements. Minimum diameter on
front wheels 17 inches. Any modifications and/or lightening
prohibited. Titanium wheel studs prohibited.
Re: who makes 1/2-20 Titanium wheel studs? [Re: John_Kunkel] #2773889
05/12/20 01:38 PM
05/12/20 01:38 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
You guys need to stop showing me this stuff lol.
Re: who makes 1/2-20 Titanium wheel studs? [Re: fullmetaljacket] #2773899
05/12/20 02:24 PM
05/12/20 02:24 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Considering the tiny weight loss and the small polar moment, the loss of strength makes this a risk with minimal return.
Boffin Emeritus
Re: who makes 1/2-20 Titanium wheel studs? [Re: Jeremiah] #2773908
05/12/20 02:52 PM
05/12/20 02:52 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
SAME!
'63 Dodge 330
11.19 @ 121 mph
Re: who makes 1/2-20 Titanium wheel studs? [Re: polyspheric] #2773909
05/12/20 03:04 PM
05/12/20 03:04 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I'm assuming this is for the rear. Anything going fast enough to benefit from Ti should have 5/8 stuff in it anyway. I like to use it on anything with a spool and/or sticky tires.
I also don't believe the Ti studs are as strong as steel. So if 1/2" steel stuff is marginal to begin with, going to Ti is asking for trouble.
Re: who makes 1/2-20 Titanium wheel studs? [Re: John_Kunkel] #2773942
05/12/20 05:44 PM
05/12/20 05:44 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Cadmium plated fasteners will fracture Ti parts. The stuff you learn while around military aviation.
Re: who makes 1/2-20 Titanium wheel studs? [Re: fullmetaljacket] #2773972
05/12/20 07:56 PM
05/12/20 07:56 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Even those who should know better trip over laws of physics.
Famous test of 3 (then current) Porsche models (1973?).
Brock Yates notices the press handout says "the wheel lugs are aluminum".
Thinking this is a typo, he asks the PR person "WTH?", who answers "Zey are lighter!".
At that point in time, writers dare not mention the fact that trailing throttle oversteer* was still killing Porsche owners....
* enter a turn too fast, back off the throttle, causes fatal oversteer, car loops
Boffin Emeritus
Re: who makes 1/2-20 Titanium wheel studs? [Re: CMcAllister] #2773996
05/12/20 09:21 PM
05/12/20 09:21 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Titanium has grades ($$$) stronger then many steels, the real issue I believe is fatigue, its fatigue property is somewhere between Alum and steel, ie it has a finite limited cyclic useful life.
I can't see a useful application for 1/2" Ti studs of any grade.
Re: who makes 1/2-20 Titanium wheel studs? [Re: jcc] #2774017
05/12/20 10:30 PM
05/12/20 10:30 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
If it's a weight issue, I would think there are many other places to save that pound or so cheaper and without hurting reliability. If it's for strength, go to 5/8" stuff.
Re: who makes 1/2-20 Titanium wheel studs? [Re: CMcAllister] #2774180
05/13/20 12:42 PM
05/13/20 12:42 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The driver's weight will vary from day-to-day more than the weight savings of Ti lugs.
Re: who makes 1/2-20 Titanium wheel studs? [Re: John_Kunkel] #2774258
05/13/20 04:15 PM
05/13/20 04:15 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
It all adds up. Every once counts
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Page 1 of 3 1 2 3
