New Mopar Part #s #2770143
05/01/20 01:01 PM
05/01/20 01:01 PM
Usa
A39Coronet Offline OP
Usa
Can anyone tell me what tail end letters mean on new Chrysler part numbers?
Ex. I'm looking for timing cover 4792795AD for a 2006-10 Charger. I'm seeing visually identical parts listed for Jeeps, but the number is 4792795AC. They "look" the same, but gotta be different in some way or else they'd have identical numbers, right?
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: New Mopar Part #s [Re: A39Coronet] #2770166
05/01/20 02:28 PM
05/01/20 02:28 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
superseded part numbers in most cases.
Re: New Mopar Part #s [Re: A39Coronet] #2770171
05/01/20 02:47 PM
05/01/20 02:47 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
From what I understand, the succession of the letters is a modification to the original part that does not affect the interchange. IOW, AC is an earlier version of AD; AD is an "improved" part.
Re: New Mopar Part #s [Re: A39Coronet] #2770180
05/01/20 03:20 PM
05/01/20 03:20 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Second character of the suffix is usually a revison which normally does not affect form, fit, or function.
If I remember correctly this is required to help keep track of things even when the part is the same but supply chain has changed.
A change of packager or tier 1 machine shop would require a suffix rev even though they're all supposed to be making
the part to the same specs, and you may not be able to see or measure any difference.
Anyway If I knew I needed an A*, I'd bolt on an AA through AZ without a whole lot of concern.
Rich H.
Esse Quam Videri
Re: New Mopar Part #s [Re: ZIPPY] #2770198
05/01/20 04:24 PM
05/01/20 04:24 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
A chance of packager or tier 1 machine shop would require a suffix rev even though they're all supposed to be making
Coorect.....If the first letter in the suffix changes. The form fit or function was affected by the change. So, AA to AB no effect on form fit function. AA to BA = Affect on form fit or function.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: New Mopar Part #s [Re: A39Coronet] #2770218
05/01/20 05:30 PM
05/01/20 05:30 PM
Usa
Usa
Great replies...thanks all!
Re: New Mopar Part #s [Re: John_Kunkel] #2770303
05/01/20 11:03 PM
05/01/20 11:03 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
That's exactly how it worked on the production assembly line.
Re: New Mopar Part #s [Re: SNK-EYZ] #2770411
05/02/20 11:53 AM
05/02/20 11:53 AM
5thAve Offline
5thAve  Offline
I've heard the letter can also change if they started using a different vendor to make it easier to identify parts if there are problems.
Re: New Mopar Part #s [Re: 70gtx440dana] #2770535
05/02/20 08:14 PM
05/02/20 08:14 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Yep, we’re on the same page.
First letter of the suffix is the design, second letter is the revision level within the context of that design.
This is as “smart” as a Mopar part number can get, other than odd-left, even-right (with few exceptions and errors), but after
Almost 9 years of it I accepted that other deal as more cultural rather than rule. (Or why would the errors be allowed to exist?).
Rich H.
Esse Quam Videri
