Re: New Mopar Part #s
[Re: A39Coronet]
#2770171
05/01/20 02:47 PM
05/01/20 02:47 PM
Posts: 25,618 Rio Linda, CA
John_Kunkel
Rio Linda, CA
From what I understand, the succession of the letters is a modification to the original part that does not affect the interchange. IOW, AC is an earlier version of AD; AD is an "improved" part.
[Re: A39Coronet]
#2770180
05/01/20 03:20 PM
05/01/20 03:20 PM
Posts: 17,800 S.E. Michigan
ZIPPY
S.E. Michigan
Second character of the suffix is usually a revison which normally does not affect form, fit, or function.
If I remember correctly this is required to help keep track of things even when the part is the same but supply chain has changed. A change of packager or tier 1 machine shop would require a suffix rev even though they're all supposed to be making the part to the same specs, and you may not be able to see or measure any difference.
Anyway If I knew I needed an A*, I'd bolt on an AA through AZ without a whole lot of concern.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2770198
05/01/20 04:24 PM
05/01/20 04:24 PM
Posts: 3,518 Lansing, MI
70gtx440dana
Lansing, MI
If I remember correctly this is required to help keep track of things even when the part is the same but supply chain has changed. A chance of packager or tier 1 machine shop would require a suffix rev even though they're all supposed to be making the part to the same specs, and you may not be able to see or measure any difference.
Anyway If I knew I needed an A*, I'd bolt on an AA through AZ without a whole lot of concern. Coorect.....If the first letter in the suffix changes. The form fit or function was affected by the change. So, AA to AB no effect on form fit function. AA to BA = Affect on form fit or function.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: John_Kunkel]
#2770303
05/01/20 11:03 PM
05/01/20 11:03 PM
Posts: 10,115 A Red State
SNK-EYZ
A Red State
From what I understand, the succession of the letters is a modification to the original part that does not affect the interchange. IOW, AC is an earlier version of AD; AD is an "improved" part. That's exactly how it worked on the production assembly line.
[Re: 70gtx440dana]
#2770535
05/02/20 08:14 PM
05/02/20 08:14 PM
ZIPPY
S.E. Michigan
Anyway If I knew I needed an A*, I'd bolt on an AA through AZ without a whole lot of concern. Coorect.....If the first letter in the suffix changes. The form fit or function was affected by the change. So, AA to AB no effect on form fit function. AA to BA = Affect on form fit or function. Yep, we’re on the same page. First letter of the suffix is the design, second letter is the revision level within the context of that design. This is as “smart” as a Mopar part number can get, other than odd-left, even-right (with few exceptions and errors), but after Almost 9 years of it I accepted that other deal as more cultural rather than rule. (Or why would the errors be allowed to exist?).
Rich H.
Esse Quam Videri
