Re: almost legal flexplate shield b body
[Re: Clanton]
#2769559
04/29/20 04:46 PM
04/29/20 04:46 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I’m confused. Is this for your new 400 transmission with the ultra shield. If so you don’t need that shield. I’m lost.
[Re: pittsburghracer]
#2769561
04/29/20 04:53 PM
04/29/20 04:53 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Oh heck no this is what I took off with the 727 I’m confused. Is this for your new 400 transmission with the ultra shield. If so you don’t need that shield. I’m lost.
[Re: Clanton]
#2769564
04/29/20 05:03 PM
04/29/20 05:03 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Oh heck no this is what I took off with the 727 I’m confused. Is this for your new 400 transmission with the ultra shield. If so you don’t need that shield. I’m lost. Ok I’m up to speed. Floor it.
[Re: Clanton]
#2769654
04/29/20 09:02 PM
04/29/20 09:02 PM
Posts: 11,611 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Mods = dead cert as far as the tech guys are concerned.
[Re: CMcAllister]
#2769657
04/29/20 09:25 PM
04/29/20 09:25 PM
Clanton
northern,Ohio,USA
I did talk to TCI and I would have to send it in to have it certed with mods done to it and it can be done. Mods = dead cert as far as the tech guys are concerned.
[Re: Clanton]
#2769833
04/30/20 02:02 PM
04/30/20 02:02 PM
Posts: 1,607 westerly, ri. usa
440lebaron
westerly, ri. usa
I believe flexplate shields have to be dated 5 years?? and without any modifications, it world probley pass at most tracks
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: Clanton]
#2769885
04/30/20 05:24 PM
04/30/20 05:24 PM
Posts: 16,928 NC
440Jim
NC
I bent over the upper part so it didn't hit the firewall and it is 2" wide and covers the starter ring by 1".I just wanted to pass on the idea,it is better than nothing. It always amazes me when a part doesn't fit a typical installation. And in this case an SFI part that technically should not be modified. At least that modified 727 flexplate shield trys to meet the intent of safety. I assume that part won't fit 99% of the factory 727 applications...? And it looks like a typical 727 flexplate shield, so most/all other brands may have the same problem. Anybody have another brand that has the same issue? (all of my race 727 cars had the CSI/CSR? composite shield that covers both the trans and flexplate areas.)
[Re: 440Jim]
#2769887
04/30/20 05:36 PM
04/30/20 05:36 PM
Clanton
northern,Ohio,USA
My fp shield is intended for a roadster/dragster body not a factory body from what I remember and nobody does make 1 that I know of so someone could cut the firewall to fit it but not me and why I did the mod. I bent over the upper part so it didn't hit the firewall and it is 2" wide and covers the starter ring by 1".I just wanted to pass on the idea,it is better than nothing. It always amazes me when a part doesn't fit a typical installation. And in this case an SFI part that technically should not be modified. At least that modified 727 flexplate shield trys to meet the intent of safety. I assume that part won't fit 99% of the factory 727 applications...? And it looks like a typical 727 flexplate shield, so most/all other brands may have the same problem. Anybody have another brand that has the same issue? (all of my race 727 cars had the CSI/CSR? composite shield that covers both the trans and flexplate areas.)
[Re: Clanton]
#2770039
05/01/20 08:08 AM
05/01/20 08:08 AM
Posts: 9,853 MI, usa
dvw
MI, usa
I've been racing mine 7 years. Its been to 11 different tracks. Teched numerous times. Car is certed to 8.50. Trans shield, yes. No flywheel shield. Never been questioned. I agree in a stock body the shield is tough to fit. Doug
[Re: dvw]
#2770057
05/01/20 08:57 AM
05/01/20 08:57 AM
Posts: 16,928 NC
440Jim
NC
I've been racing mine 7 years. Its been to 11 different tracks. Teched numerous times. Car is certed to 8.50. Trans shield, yes. No flywheel shield. Never been questioned. I agree in a stock body the shield is tough to fit. Doug At the track I have seen others that have had the ring gear come apart on their race cars. It peels off (weld failure) and cuts right through the car like a saw. These were SFI items (on Power Glide transmissions). It may go up, down left or right.
[Re: 440Jim]
#2770066
05/01/20 09:56 AM
05/01/20 09:56 AM
Clanton
northern,Ohio,USA
Even the CF shield will let parts fly I've been racing mine 7 years. Its been to 11 different tracks. Teched numerous times. Car is certed to 8.50. Trans shield, yes. No flywheel shield. Never been questioned. I agree in a stock body the shield is tough to fit. Doug At the track I have seen others that have had the ring gear come apart on their race cars. It peels off (weld failure) and cuts right through the car like a saw. These were SFI items (on Power Glide transmissions). It may go up, down left or right.
