almost legal flexplate shield b body #2769554
04/29/20 04:28 PM
04/29/20 04:28 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I did some mods to at least have 1 on but the mod was not certed.
Re: almost legal flexplate shield b body [Re: Clanton] #2769559
04/29/20 04:46 PM
04/29/20 04:46 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I’m confused. Is this for your new 400 transmission with the ultra shield. If so you don’t need that shield. I’m lost.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: almost legal flexplate shield b body [Re: pittsburghracer] #2769561
04/29/20 04:53 PM
04/29/20 04:53 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Oh heck no this is what I took off with the 727
Re: almost legal flexplate shield b body [Re: Clanton] #2769564
04/29/20 05:03 PM
04/29/20 05:03 PM
PA.
"Little"John
"Little"John
PA.
Ok I’m up to speed. Floor it.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: almost legal flexplate shield b body [Re: Clanton] #2769578
04/29/20 05:35 PM
04/29/20 05:35 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I bent over the upper part so it didn't hit the firewall and it is 2" wide and covers the starter ring by 1".I just wanted to pass on the idea,it is better than nothing.
Re: almost legal flexplate shield b body [Re: Clanton] #2769625
04/29/20 07:34 PM
04/29/20 07:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Just use grade 8 or harder bolts to mount it
wave
Re: almost legal flexplate shield b body [Re: MR_P_BODY] #2769648
04/29/20 08:52 PM
04/29/20 08:52 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I used allen bolts in the top 2 holes and bolts in the others
Re: almost legal flexplate shield b body [Re: Clanton] #2769654
04/29/20 09:02 PM
04/29/20 09:02 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Mods = dead cert as far as the tech guys are concerned.
Re: almost legal flexplate shield b body [Re: Clanton] #2769656
04/29/20 09:20 PM
04/29/20 09:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Should use the allens on them all
wave
Re: almost legal flexplate shield b body [Re: CMcAllister] #2769657
04/29/20 09:25 PM
04/29/20 09:25 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I did talk to TCI and I would have to send it in to have it certed with mods done to it and it can be done.
Re: almost legal flexplate shield b body [Re: Clanton] #2769833
04/30/20 02:02 PM
04/30/20 02:02 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
I believe flexplate shields have to be dated 5 years?? and without any modifications, it world probley pass at most tracks
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: almost legal flexplate shield b body [Re: 440lebaron] #2769882
04/30/20 05:14 PM
04/30/20 05:14 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Most tracks just want to see something there but it is hard to see any mods just looking
Re: almost legal flexplate shield b body [Re: Clanton] #2769885
04/30/20 05:24 PM
04/30/20 05:24 PM
NC
440Jim Offline
440Jim  Offline
NC
It always amazes me when a part doesn't fit a typical installation. And in this case an SFI part that technically should not be modified. At least that modified 727 flexplate shield trys to meet the intent of safety.
I assume that part won't fit 99% of the factory 727 applications...?
And it looks like a typical 727 flexplate shield, so most/all other brands may have the same problem. Anybody have another brand that has the same issue?
(all of my race 727 cars had the CSI/CSR? composite shield that covers both the trans and flexplate areas.)
Re: almost legal flexplate shield b body [Re: 440Jim] #2769887
04/30/20 05:36 PM
04/30/20 05:36 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
My fp shield is intended for a roadster/dragster body not a factory body from what I remember and nobody does make 1 that I know of so someone could cut the firewall to fit it but not me and why I did the mod.
Re: almost legal flexplate shield b body [Re: Clanton] #2770039
05/01/20 08:08 AM
05/01/20 08:08 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I've been racing mine 7 years. Its been to 11 different tracks. Teched numerous times. Car is certed to 8.50. Trans shield, yes. No flywheel shield. Never been questioned. I agree in a stock body the shield is tough to fit.
Doug
Re: almost legal flexplate shield b body [Re: dvw] #2770051
05/01/20 08:35 AM
05/01/20 08:35 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
the CSR Kevlar shield covers both flywheel and transmission - it has two SFI certs on it - that is the most common one being run - fits most cars if you beat and roll the body seam in the tunnel
What i see more disturbing is that hokey plastic oil pressure line you have on there - I would think about changing that to a braided set-up - Summit sells a nice kit with fittings - would be terrible to watch your car burn up when it melts or breaks because it gets brittle with age
Re: almost legal flexplate shield b body [Re: dvw] #2770057
05/01/20 08:57 AM
05/01/20 08:57 AM
NC
440Jim Offline
440Jim  Offline
NC
Doug
At the track I have seen others that have had the ring gear come apart on their race cars. It peels off (weld failure) and cuts right through the car like a saw. These were SFI items (on Power Glide transmissions). It may go up, down left or right.
Re: almost legal flexplate shield b body [Re: DoubleD] #2770064
05/01/20 09:40 AM
05/01/20 09:40 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I will look into a oil line today.
Re: almost legal flexplate shield b body [Re: 440Jim] #2770066
05/01/20 09:56 AM
05/01/20 09:56 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Even the CF shield will let parts fly
Doug
