727 slipping question #276666
04/04/09 01:18 PM
04/04/09 01:18 PM
Ft. Lauderdale, FL
solarguy Offline OP
solarguy  Offline OP
Ft. Lauderdale, FL
I have a 727 behind my 340. It has a TF-2 shift kit, an aux cooler in addition to the rad, and I swapped the converter to a turbo action 10" 3000 stall a couple of months ago. During hard launches, I occasionly get what feels like the trans slipping when it first gets into 3rd gear. It happens more readily the longer I drive, (heats up). If I let off the throttle a bit, it 'catches" and goes well from there. I'm thinking the clutches are slipping a bit and was wondering if increasing the line pressure would be a good remedy? Right now, pressure is adjusted per the TF-2 instructions. I felt this happening before the convertor swap but it is exagerated now with the higher stall. Any advice would be appreciated.
Re: 727 slipping question [Re: solarguy] #276667
04/04/09 01:31 PM
04/04/09 01:31 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
if it only happens on the shift into 3rd upping the line pressure may cover it up for a short time but it is not the fix I would be looking at the clutch pack it self.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 727 slipping question [Re: dusturbd340W5] #276668
04/04/09 01:37 PM
04/04/09 01:37 PM
Az
Crizila Offline
Crizila  Offline
Az
No two ways about it. The front clutch pack is toast. When you have it rebuilt ( and you will soon ) go to a 4 clutch front drum. CRT can set you up with everything you will need. Problem fixed - perminently.
Fastest 300
Re: 727 slipping question [Re: Crizila] #276669
04/04/09 02:14 PM
04/04/09 02:14 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Once they slip they don't heal up by themselves.
Re: 727 slipping question [Re: MoparforLife] #276670
04/04/09 04:06 PM
04/04/09 04:06 PM
Ft. Lauderdale, FL
solarguy Offline OP
solarguy  Offline OP
Ft. Lauderdale, FL
Thanks for the responses. I know boosting the line pressure would only be temp if it worked at all. I want to mainly do it as a digagnostic aid. Is there anyway to positively confirm clutch pack outside of a teardown inspection?
I originally thought the fuel pump was getting weak at the top end. Car would cut out for a few seconds, going into 3rd at high rpm, let off gas, ok. No Surge in RPM's felt like I would expect from slipping clutches. It felt like running out of gas for a few seconds. A new fuel pump and a fresh tune and high end snag at 3rd still happens. If I shift manually, no snags. Again, it only happens in auto and only when getting on it hard. Kickdown is adjusted nicely and shift points are good
Re: 727 slipping question [Re: solarguy] #276671
04/04/09 04:10 PM
04/04/09 04:10 PM
Florida STAYcation
dOc … Online penguin-006
The village idiot's idiot
dOc …  Online Penguin-006
Florida STAYcation
Do you have a way to check pressures ?
Re: 727 slipping question [Re: dOc …] #276672
04/04/09 04:18 PM
04/04/09 04:18 PM
Ft. Lauderdale, FL
solarguy Offline OP
solarguy  Offline OP
Ft. Lauderdale, FL
No, current setting allows 5 more turns counterclockwise from present setting per TF2 settings. Those settings were fine for the 3 years the shift kits been in. I know a guage would help alot
Re: 727 slipping question [Re: solarguy] #276673
04/04/09 04:23 PM
04/04/09 04:23 PM
Florida STAYcation
Florida STAYcation
I would invest in at least a cheapo 150 psi oil pressure gauge.
And then match up the fittings to the plug on the trans.
