727 slipping question
#276666
04/04/09 01:18 PM
04/04/09 01:18 PM
Posts: 1,286 Ft. Lauderdale, FL
solarguy
Ft. Lauderdale, FL
I have a 727 behind my 340. It has a TF-2 shift kit, an aux cooler in addition to the rad, and I swapped the converter to a turbo action 10" 3000 stall a couple of months ago. During hard launches, I occasionly get what feels like the trans slipping when it first gets into 3rd gear. It happens more readily the longer I drive, (heats up). If I let off the throttle a bit, it 'catches" and goes well from there. I'm thinking the clutches are slipping a bit and was wondering if increasing the line pressure would be a good remedy? Right now, pressure is adjusted per the TF-2 instructions. I felt this happening before the convertor swap but it is exagerated now with the higher stall. Any advice would be appreciated.
Re: 727 slipping question
[Re: solarguy]
#276667
04/04/09 01:31 PM
04/04/09 01:31 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
if it only happens on the shift into 3rd upping the line pressure may cover it up for a short time but it is not the fix I would be looking at the clutch pack it self.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#276668
04/04/09 01:37 PM
04/04/09 01:37 PM
Posts: 7,506 Az
Crizila
Az
No two ways about it. The front clutch pack is toast. When you have it rebuilt ( and you will soon ) go to a 4 clutch front drum. CRT can set you up with everything you will need. Problem fixed - perminently.
Fastest 300
