Re: TH400 to RB in 69 b body info
[Re: AndyF]
#2774516
05/14/20 01:51 PM
05/14/20 01:51 PM
Posts: 4,682 On the parachute mount
n20mstr
Check the depth going into the adapter with the converter, mine only had .030 . I took .100 off The adapter so the converter had more clearance . I checked it with some play-do
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#2774561
05/14/20 03:40 PM
05/14/20 03:40 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
I will talk to you about this later today.I have no base measurements to go by. Check the depth going into the adapter with the converter, mine only had .030 . I took .100 off The adapter so the converter had more clearance . I checked it with some play-do
[Re: Cab_Burge]
#2774732
05/15/20 08:25 AM
05/15/20 08:25 AM
Clanton
northern,Ohio,USA
I think the biggest offset I can get is .015 and to pull the 1's in the engine all I have is some visegrips so I hope that works.Moving the bell .015"I don't think is going to effect the starter much.
[Re: DoubleD]
#2774788
05/15/20 11:18 AM
05/15/20 11:18 AM
Clanton
northern,Ohio,USA
I didn't.I measured for the low spot and 0 the dial.I still have it set in place to measure today but I am confident it is reading okay in the small steps I am turning it and the angle is small. .032 off center? - I think you better double check your measurements again - I have never seen one out that far
How are you centering your dial indicator on the Crank??
[Re: DoubleD]
#2774790
05/15/20 11:19 AM
05/15/20 11:19 AM
Posts: 2,175 Duloc
The Shadow
Duloc
How are you centering your dial indicator on the Crank?? Doesn't need centering on the crank
[Re: n20mstr]
#2774795
05/15/20 11:29 AM
05/15/20 11:29 AM
Clanton
northern,Ohio,USA
When I get that far and have the converter I will lay it against the flex plate and check it.Thank youThe I.D. was 1.704 Check the depth going into the adapter with the converter, mine only had .030 . I took .100 off The adapter so the converter had more clearance . I checked it with some play-do
[Re: Clanton]
#2774948
05/15/20 07:17 PM
05/15/20 07:17 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Hey Mike if you need a rock solid dial indicator mount that bolts to the crank flange you can use mine. I had it made strong so I could get my bell dialed in without the indicator moving around. Let me know and I can meet you somewhere and get it to you. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#2774967
05/15/20 08:20 PM
05/15/20 08:20 PM
Clanton
northern,Ohio,USA
What a great offer Thank you.I think I am within .003 soI have had enough for now and will move on to getting a converter,driveshaft n yokeThe solid mount sounds interesting if you have a pic? Hey Mike if you need a rock solid dial indicator mount that bolts to the crank flange you can use mine. I had it made strong so I could get my bell dialed in without the indicator moving around. Let me know and I can meet you somewhere and get it to you. Gus
