Re: 440 Source crank drilled for pilot bushing?
[Re: 70VcodeCoronetRT]
#2762678
04/11/20 12:27 PM
04/11/20 12:27 PM
Posts: 43,308 Bend,OR USA
Cab_Burge
I bought a 3.915 BB crank at least 10 years ago for a 470 auto build. I'm thinking of going to a 4 speed setup. Are all the 440 Source cranks drilled for a pilot bushing? Thanks Why are you asking and concern about all of them? Is yours machined properly or not? ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif)
#2762680
04/11/20 12:29 PM
04/11/20 12:29 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Mine was, and I used the roller bearing from a Magnum engine. Mancini has them too.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
#2762682
04/11/20 12:38 PM
04/11/20 12:38 PM
Cab_Burge
Did yours say made in China when you bought it? If not, it wasn't was it ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) I sold a lot of used Mopar BB engine parts to Brandon years ago when he was stocking up to open 440 Source, maybe the crank you have was a used stock 440 crankshaft offset ground to 3.91 stroke that he had back then ![work work](/ubbthreads/images/graemlins/custom/work.gif) Why are you asking questions that you have the answer to already ![work work](/ubbthreads/images/graemlins/custom/work.gif)
#2762736
04/11/20 03:26 PM
04/11/20 03:26 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
WOW , sorry to ask if anyone have ever had a 440source crank that was not drilled. Yeah people are getting a little "snappy" these days ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) BTW my Eagle crank was NOT drilled and I had to chop a few perfectly good 18 spline input shafts ![mad mad](/ubbthreads/images/graemlins/custom/mad.gif) Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
