440 Source crank drilled for pilot bushing? #2762673
04/11/20 12:22 PM
04/11/20 12:22 PM
Nebraska
70VcodeCoronetRT Offline OP
Nebraska
I bought a 3.915 BB crank at least 10 years ago for a 470 auto build. I'm thinking of going to a 4 speed setup. Are all the 440 Source cranks drilled for a pilot bushing? Thanks
Re: 440 Source crank drilled for pilot bushing? [Re: 70VcodeCoronetRT] #2762678
04/11/20 12:27 PM
04/11/20 12:27 PM
Why are you asking and concern about all of them?
Is yours machined properly or not? scope
Re: 440 Source crank drilled for pilot bushing? [Re: 70VcodeCoronetRT] #2762679
04/11/20 12:27 PM
04/11/20 12:27 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
Why don't you ask 440Source ?!?!?
Re: 440 Source crank drilled for pilot bushing? [Re: 70VcodeCoronetRT] #2762680
04/11/20 12:29 PM
04/11/20 12:29 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Mine was, and I used the roller bearing from a Magnum engine. Mancini has them too.
Re: 440 Source crank drilled for pilot bushing? [Re: Stanton] #2762681
04/11/20 12:29 PM
04/11/20 12:29 PM
Nebraska
Nebraska
Their site says yes. But I'm curious if anyone has run into one that wasn't. They are made in China. frown
Re: 440 Source crank drilled for pilot bushing? [Re: 70VcodeCoronetRT] #2762682
04/11/20 12:38 PM
04/11/20 12:38 PM
Did yours say made in China when you bought it?
If not, it wasn't was it shruggy
I sold a lot of used Mopar BB engine parts to Brandon years ago when he was stocking up to open 440 Source, maybe the crank you have was a used stock 440 crankshaft offset ground to 3.91 stroke that he had back then work
Why are you asking questions that you have the answer to already work
Re: 440 Source crank drilled for pilot bushing? [Re: Cab_Burge] #2762723
04/11/20 02:40 PM
04/11/20 02:40 PM
Nebraska
Nebraska
WOW , sorry to ask if anyone have ever had a 440source crank that was not drilled.
Re: 440 Source crank drilled for pilot bushing? [Re: 70VcodeCoronetRT] #2762736
04/11/20 03:26 PM
04/11/20 03:26 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Yeah people are getting a little "snappy" these days shruggy BTW my Eagle crank was NOT drilled and I had to chop a few perfectly good 18 spline input shafts mad
Gus beer
64 Plymouth Savoy
Dana 60
Re: 440 Source crank drilled for pilot bushing? [Re: fourgearsavoy] #2762831
04/11/20 07:48 PM
04/11/20 07:48 PM
wine country
8
8urvette Offline
8urvette  Offline
wine country
My 440 source crank was drilled. I bought it about 12 years ago.
It was for an auto, then I went 4 speed.
Re: 440 Source crank drilled for pilot bushing? [Re: 70VcodeCoronetRT] #2764356
04/15/20 05:56 PM
04/15/20 05:56 PM
Idaho
Runner Offline
Runner  Offline
Idaho
even if its not you can trim your input shaft and use one of these http://www.brewersperformance.com/proddetail.php?prod=PB5300
