chrome 426 hemi valve covers #2763062
04/12/20 02:24 PM
04/12/20 02:24 PM
saint paul mn.
johnzgarage Offline OP
saint paul mn.
Im having trouble trying to mount a pair of cheap chrome 426 hemi valve covers. The felpro double cork gaskets dont fit inside the covers......they appear to be to big ? The gaskets fit the heads nice ,but the covers wont mate with them. The flanged edges/lip of the covers, look like they are made wrong.....am i right ? should i get different covers, or beat the cheap chrome covers to fit ? Has anyone had this problem ?
Re: chrome 426 hemi valve covers [Re: johnzgarage] #2763064
04/12/20 02:32 PM
04/12/20 02:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I believe you said the magic word... CHEAP.. I would try another cover.. thats just me
wave
Re: chrome 426 hemi valve covers [Re: MR_P_BODY] #2763104
04/12/20 03:53 PM
04/12/20 03:53 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I think you can work with them. You might have to push the gasket under the lip as you go around. You might try to use black weatherstripping on the valve cover and stick the gasket to it before installing.
2011 Drag Pak Challenger
Re: chrome 426 hemi valve covers [Re: rickseeman] #2763160
04/12/20 07:04 PM
04/12/20 07:04 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Another thing I have done in these cases it to bolt the valve covers on the gaskets so as to leave the outside lip impressions. Then remove them and trim with a bench grinder. Messy and bit time consuming, but it works.
On most of the cheap stamped valve covers, the metal is so thin that it dimples around the nuts. There are hundreds of different valve cover hold downs to choose from on ebag that will help with that.
Master, again and still
Re: chrome 426 hemi valve covers [Re: DaveRS23] #2763174
04/12/20 07:58 PM
04/12/20 07:58 PM
A727Tflite Offline
A727Tflite  Offline
If the covers fit the head using studs, then see if the gaskets fit the covers and if the hole says line up.
If so then as above - just tuck the gasket in working aroun the cover.
Had to do that many times with wedge and Hemi.
Re: chrome 426 hemi valve covers [Re: A727Tflite] #2763306
04/13/20 08:54 AM
04/13/20 08:54 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Now that I think about it the last time I used those valve covers and those gaskets I did have to get some side cutters and trim them to get them to work.
