Re: chrome 426 hemi valve covers
[Re: MR_P_BODY]
#2763104
04/12/20 03:53 PM
04/12/20 03:53 PM
Posts: 2,631 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I think you can work with them. You might have to push the gasket under the lip as you go around. You might try to use black weatherstripping on the valve cover and stick the gasket to it before installing.
2011 Drag Pak Challenger
[Re: rickseeman]
#2763160
04/12/20 07:04 PM
04/12/20 07:04 PM
Posts: 12,009 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Another thing I have done in these cases it to bolt the valve covers on the gaskets so as to leave the outside lip impressions. Then remove them and trim with a bench grinder. Messy and bit time consuming, but it works.
On most of the cheap stamped valve covers, the metal is so thin that it dimples around the nuts. There are hundreds of different valve cover hold downs to choose from on ebag that will help with that.
Master, again and still
[Re: A727Tflite]
#2763306
04/13/20 08:54 AM
04/13/20 08:54 AM
rickseeman
Stuttgart, Arkansas
Now that I think about it the last time I used those valve covers and those gaskets I did have to get some side cutters and trim them to get them to work.
