Trans lines #2761282
04/07/20 10:01 PM
04/07/20 10:01 PM
W.Va
fowl play Offline OP
W.Va
What do you use for trans cooler lines? Thinking of changing mine. What size?
Re: Trans lines [Re: fowl play] #2761286
04/07/20 10:09 PM
04/07/20 10:09 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
5/16 line
mancinni has nice pre formed ones !
Re: Trans lines [Re: fowl play] #2761309
04/07/20 11:09 PM
04/07/20 11:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
That would depend on the trans... the 904 and 727 uses 5/16" and the 500 type use 3/8"
wave
Re: Trans lines [Re: fowl play] #2761320
04/07/20 11:37 PM
04/07/20 11:37 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Race car? Street car? OEM? What cooler? Where is it mounted? What trans?
Re: Trans lines [Re: CMcAllister] #2761369
04/08/20 07:37 AM
04/08/20 07:37 AM
W.Va
W.Va
727 trans race car only
Re: Trans lines [Re: fowl play] #2761455
04/08/20 11:51 AM
04/08/20 11:51 AM
The Great State of PA
tabletop390 Offline
tabletop390  Offline
I used the stainless braided line kit from CRT. Worked really well.
https://www.coperacingtrans.com/?product=cooler-install-kit
Re: Trans lines [Re: fowl play] #2761467
04/08/20 12:11 PM
04/08/20 12:11 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Stainless braided, usually make my own
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Trans lines [Re: W.I.N. Racing] #2761488
04/08/20 01:18 PM
04/08/20 01:18 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
-6 teflon lined hose - like Aeroquip's TFE, .320"ID - with appropriate fittings and adapters. Use a cooler with threaded connections. The old rubber hose and hose clamps on barbed fittings are no good and create a huge mess when they blow apart.
I've mounted this stuff under the car, sometimes with a cooler with a small dedicated fan for the really abusive combinations, with good results. Saves all the plumbing and crap at the front of the car.
I've used -5 stuff when using it as connections for 5/16 tubing, but that stuff is oddball. -6 is much easier.
Re: Trans lines [Re: fowl play] #2761498
04/08/20 01:59 PM
04/08/20 01:59 PM
New York
polyspheric Offline
polyspheric  Offline
New York
3/8" Bundyweld brake line with compression fittings and very short pieces of braided line where needed for small bends.
Using 3,000 psi stainle$$ braid for a cooler line is a bit overkill....
Boffin Emeritus
Re: Trans lines [Re: polyspheric] #2761528
04/08/20 02:52 PM
04/08/20 02:52 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
That will work IF the steel line is properly flared and/or adapted to AN or SAE and the hose installed using the correct threaded fittings. Hose clamps on braided hose is a mess looking for a place to happen.
I'm OK with overkill if it means I don't have to worry about it failing.
Re: Trans lines [Re: CMcAllister] #2761563
04/08/20 04:36 PM
04/08/20 04:36 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
i guess looking at the Cope site, the fittings for the lines at the trans should be 1/4" npt to whatever AN size you use.
I just ordered a derale stacked plate cooler from Mancini to hook up on my car since the rubber hose and clamps on the radiator trans cooler won't stop leaking...plus the existing steel lines rub on the everything...
probably just going to use some kind of flexible line or steel braided since moving steel tubing lines out of the way to pull the motor/trans seems annoying.
Re: Trans lines [Re: krautrock] #2761677
04/08/20 07:56 PM
04/08/20 07:56 PM
You can order 1/4 NPT to #6 AN male adapter fittings and use #6 AN hose ends on #6 AN PTFE lined (Teflon) hose to make your own flexible tranny cooler lines up scope
I do on my race cars wrench
Re: Trans lines [Re: Cab_Burge] #2761887
04/09/20 12:11 PM
04/09/20 12:11 PM
moparx Offline
moparx  Offline
the fittings on a 727 are 1/8NTP, not 1/4, correct ?
beer
Re: Trans lines [Re: moparx] #2761902
04/09/20 12:59 PM
04/09/20 12:59 PM
beer
Your probably correct up I'm not sure confused workMaybe shruggy
When it gets down to using them I take them off the shelf and use them without looking at the numbers on the carton realcrazy
Re: Trans lines [Re: Cab_Burge] #2762295
04/10/20 01:07 PM
04/10/20 01:07 PM
moparx Offline
moparx  Offline
well, just to be sure my feeble old mind wasn't spouting BS information, i went out into the shop and checked a 727 that was on the cart.
it is indeed 1/8" NPT thread for the cooler lines.
hopefully, there was no confusion caused.
beer
Re: Trans lines [Re: moparx] #2762303
04/10/20 01:20 PM
04/10/20 01:20 PM
Washington
hemienvy Offline
hemienvy  Offline
Washington
How high is the pressure in the cooler lines ?
Re: Trans lines [Re: hemienvy] #2762320
04/10/20 01:45 PM
04/10/20 01:45 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Maybe 5-100PSI depending on the trans and how it's set up. Not much, but the chemicals in the oil and the heat need to be taken into consideration when choosing hose material and construction. Even the rubber lined AQP style hose is questionable.
There are -6 x 1/8" NPSM fittings available which rely on a gasket to seal vs. pipe thread. Helps eliminate the possibility of cracking a case from over tightening NPT fittings.
Re: Trans lines [Re: hemienvy] #2762323
04/10/20 01:47 PM
04/10/20 01:47 PM
moparx Offline
moparx  Offline
somewhere around 15-30 i think. shruggy
hopefully, someone can confirm this. i looked in the FSM and the ATSG books i have, and couldn't find it.
i just did a quick look, so i may have missed it.
beer
Re: Trans lines [Re: moparx] #2762388
04/10/20 03:58 PM
04/10/20 03:58 PM
I'm sure the pressure and volume are different at idle RPM than at 5500 RPM work grin
Re: Trans lines [Re: Cab_Burge] #2762408
04/10/20 04:38 PM
04/10/20 04:38 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I know some will think I'm realcrazy, and it is a racecar, but my bracket car has rubber-lined -4 ss braid and its been on there for at least 20 years.
