Re: Trans lines
[Re: fowl play]
#2761320
04/07/20 11:37 PM
04/07/20 11:37 PM
Posts: 11,526 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Race car? Street car? OEM? What cooler? Where is it mounted? What trans?
Re: Trans lines
[Re: fowl play]
#2761467
04/08/20 12:11 PM
04/08/20 12:11 PM
Posts: 2,105 Byron, NY
W.I.N. Racing
Byron, NY
Stainless braided, usually make my own
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Trans lines
[Re: W.I.N. Racing]
#2761488
04/08/20 01:18 PM
04/08/20 01:18 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
-6 teflon lined hose - like Aeroquip's TFE, .320"ID - with appropriate fittings and adapters. Use a cooler with threaded connections. The old rubber hose and hose clamps on barbed fittings are no good and create a huge mess when they blow apart.
I've mounted this stuff under the car, sometimes with a cooler with a small dedicated fan for the really abusive combinations, with good results. Saves all the plumbing and crap at the front of the car.
I've used -5 stuff when using it as connections for 5/16 tubing, but that stuff is oddball. -6 is much easier.
Re: Trans lines
[Re: fowl play]
#2761498
04/08/20 01:59 PM
04/08/20 01:59 PM
Posts: 4,206 New York
polyspheric
New York
3/8" Bundyweld brake line with compression fittings and very short pieces of braided line where needed for small bends. Using 3,000 psi stainle$$ braid for a cooler line is a bit overkill....
Boffin Emeritus
Re: Trans lines
[Re: polyspheric]
#2761528
04/08/20 02:52 PM
04/08/20 02:52 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
3/8" Bundyweld brake line with compression fittings and very short pieces of braided line where needed for small bends. Using 3,000 psi stainle$$ braid for a cooler line is a bit overkill.... That will work IF the steel line is properly flared and/or adapted to AN or SAE and the hose installed using the correct threaded fittings. Hose clamps on braided hose is a mess looking for a place to happen. I'm OK with overkill if it means I don't have to worry about it failing.
Re: Trans lines
[Re: krautrock]
#2761677
04/08/20 07:56 PM
04/08/20 07:56 PM
Posts: 43,119 Bend,OR USA
Cab_Burge
You can order 1/4 NPT to #6 AN male adapter fittings and use #6 AN hose ends on #6 AN PTFE lined (Teflon) hose to make your own flexible tranny cooler lines I do on my race cars
Re: Trans lines
[Re: Cab_Burge]
#2762295
04/10/20 01:07 PM
04/10/20 01:07 PM
Posts: 19,342 north of coder
moparx
well, just to be sure my feeble old mind wasn't spouting BS information, i went out into the shop and checked a 727 that was on the cart. it is indeed 1/8" NPT thread for the cooler lines. hopefully, there was no confusion caused.
Re: Trans lines
[Re: hemienvy]
#2762320
04/10/20 01:45 PM
04/10/20 01:45 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
How high is the pressure in the cooler lines ? Maybe 5-100PSI depending on the trans and how it's set up. Not much, but the chemicals in the oil and the heat need to be taken into consideration when choosing hose material and construction. Even the rubber lined AQP style hose is questionable. There are -6 x 1/8" NPSM fittings available which rely on a gasket to seal vs. pipe thread. Helps eliminate the possibility of cracking a case from over tightening NPT fittings.
