Dimmable LED Dash Lights #2759417
04/03/20 11:42 AM
04/03/20 11:42 AM
Slantytown
DUFFMAN Offline OP
Ask And Ye Shall Receive
DUFFMAN  Offline OP
Slantytown
Anyone know where to find LED 194 bulbs that are actually dimmable so that they can be used as dash lights? I'm currently putting the gauge pod together for my Coronet and I'd like to replace all the bulbs with LEDs while it's out and easiest to do.
No longer taking $h!t from anyone!
Re: Dimmable LED Dash Lights [Re: DUFFMAN] #2759432
04/03/20 12:08 PM
04/03/20 12:08 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
On my boat I purchased a special dimer for LED lights. Not an easy way to integrate into our old mopars. May need to bypass and hide the LED dimmer under the dash.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Dimmable LED Dash Lights [Re: DUFFMAN] #2759459
04/03/20 01:10 PM
04/03/20 01:10 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
The original incandescent bulbs were dimmed by reducing the voltage, LEDs cannot function the same. LEDs are dimmed by way of pulse-width modulation, sending a 12v signal in different duty cycles to reduce the output.
You would need to change your dimmer to one that provides a PWM output.
https://www.superbrightleds.com/mor...o2PMrlYJMmMTjY3idyaELvGuMMBoC5EAQAvD_BwE
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Dimmable LED Dash Lights [Re: GoodysGotaCuda] #2759483
04/03/20 01:48 PM
04/03/20 01:48 PM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
One that used the voltage coming from the stock dimmer to control the PMW would be ideal.
Re: Dimmable LED Dash Lights [Re: Sniper] #2759636
04/03/20 08:38 PM
04/03/20 08:38 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
https://www.superbrightleds.com/cat/miniature-wedge-base/filter/Cross_Reference_Number,194,21,201:
Used these in several Mopars. They plug right in and are dimmable via the stock headlight switch. Use same color LED as the lens in the dash
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2022 Can Am Spyder RTL
Re: Dimmable LED Dash Lights [Re: RealWing] #2759726
04/04/20 08:23 AM
04/04/20 08:23 AM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
I used these in my 1970 Monte Carlo as well, plug and play with nothing additional. They dim, but a bit "choppy" compared to standard bulbs. They don't dim smooth, but do dim. Once they get so low, they turn off vs barely on like standard ones. Not sure if that explains it. I will see if I can get them to load onto youtube and share a link.
https://www.youtube.com/channel/UCzOk5IRf_-jk8kBf1kQ38Uw
Instead of two separate links, here's my videos that are public. One shows on to off and another off to on. Bulb on left is standard and the other console and pod bulbs are LED. LED are way brighter for sure.
Re: Dimmable LED Dash Lights [Re: RealWing] #2760052
04/04/20 04:57 PM
04/04/20 04:57 PM
GMP440 Offline
GMP440  Offline
Good to know. What level of brightness for the LED's should we be looking for?
Re: Dimmable LED Dash Lights [Re: GoodysGotaCuda] #2760224
04/05/20 02:20 AM
04/05/20 02:20 AM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
This is false. LEDs are Not all created equal! I have a factory 1970 dimmer in my Superbee and LED dash bulbs from superbrightleds.com and they dim perfectly smooth from dim to bright with zero stepping. I recommend going with the blue colored bulbs for the dimmable lights, red for brake, green for blinkers etc. the brightness is so much more intense that the white ones bleed through the lenses and make the colors look pale.
I’m listening.
Re: Dimmable LED Dash Lights [Re: RealWing] #2760267
04/05/20 08:41 AM
04/05/20 08:41 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Of the eleven shown, which style did you use? With the choice of varying intensities and brightness I'd hate to re-invent the wheel!!
Re: Dimmable LED Dash Lights [Re: Big Bad Bee] #2760286
04/05/20 09:25 AM
04/05/20 09:25 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I wasn't aware of that. Nice.
2020 RAM 1500
Re: Dimmable LED Dash Lights [Re: DUFFMAN] #2760610
04/06/20 01:32 AM
04/06/20 01:32 AM
KS
4x4race Offline
4x4race  Offline
KS
Call https://www.allmoparparts.com/. Mostly I get my parts there.
