Dimmable LED Dash Lights
#2759417
04/03/20 11:42 AM
04/03/20 11:42 AM
Posts: 11,269 Slantytown
DUFFMAN
Ask And Ye Shall Receive
Slantytown
Anyone know where to find LED 194 bulbs that are actually dimmable so that they can be used as dash lights? I'm currently putting the gauge pod together for my Coronet and I'd like to replace all the bulbs with LEDs while it's out and easiest to do.
No longer taking $h!t from anyone!
Re: Dimmable LED Dash Lights
[Re: DUFFMAN]
#2759432
04/03/20 12:08 PM
04/03/20 12:08 PM
Posts: 5,139 East Aurora (Buffalo) NY
RoadRunner
On my boat I purchased a special dimer for LED lights. Not an easy way to integrate into our old mopars. May need to bypass and hide the LED dimmer under the dash.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: Sniper]
#2759636
04/03/20 08:38 PM
04/03/20 08:38 PM
Posts: 315 Ontario, Canada
RealWing
Ontario, Canada
https://www.superbrightleds.com/cat/miniature-wedge-base/filter/Cross_Reference_Number,194,21,201:
Used these in several Mopars. They plug right in and are dimmable via the stock headlight switch. Use same color LED as the lens in the dash Jim
1970 Superbird 440-6bbl, auto 1969 Barracuda 340-4bbl, FB Formula S auto 1969 Barracuda 6.1 L Hemi, 5 speed, Convertible 2022 Can Am Spyder RTL
[Re: RealWing]
#2759726
04/04/20 08:23 AM
04/04/20 08:23 AM
Posts: 5,656 Port Huron, Michigan
MI_Custumz
Used these in several Mopars. They plug right in and are dimmable via the stock headlight switch. Use same color LED as the lens in the dash Jim I used these in my 1970 Monte Carlo as well, plug and play with nothing additional. They dim, but a bit "choppy" compared to standard bulbs. They don't dim smooth, but do dim. Once they get so low, they turn off vs barely on like standard ones. Not sure if that explains it. I will see if I can get them to load onto youtube and share a link. https://www.youtube.com/channel/UCzOk5IRf_-jk8kBf1kQ38UwInstead of two separate links, here's my videos that are public. One shows on to off and another off to on. Bulb on left is standard and the other console and pod bulbs are LED. LED are way brighter for sure.
[Re: GoodysGotaCuda]
#2760224
04/05/20 02:20 AM
04/05/20 02:20 AM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
This is false. LEDs are Not all created equal! I have a factory 1970 dimmer in my Superbee and LED dash bulbs from superbrightleds.com and they dim perfectly smooth from dim to bright with zero stepping. I recommend going with the blue colored bulbs for the dimmable lights, red for brake, green for blinkers etc. the brightness is so much more intense that the white ones bleed through the lenses and make the colors look pale.
I’m listening.
[Re: RealWing]
#2760267
04/05/20 08:41 AM
04/05/20 08:41 AM
Posts: 10,755 North Dakota
6PakBee
North Dakota
Used these in several Mopars. They plug right in and are dimmable via the stock headlight switch. Use same color LED as the lens in the dash Jim Of the eleven shown, which style did you use? With the choice of varying intensities and brightness I'd hate to re-invent the wheel!!
[Re: Big Bad Bee]
#2760286
04/05/20 09:25 AM
04/05/20 09:25 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
This is false. LEDs are Not all created equal! I have a factory 1970 dimmer in my Superbee and LED dash bulbs from superbrightleds.com and they dim perfectly smooth from dim to bright with zero stepping. I recommend going with the blue colored bulbs for the dimmable lights, red for brake, green for blinkers etc. the brightness is so much more intense that the white ones bleed through the lenses and make the colors look pale. I wasn't aware of that. Nice.
