Strange oil pressure sender fitting! #2756634
03/27/20 08:58 PM
03/27/20 08:58 PM
New York
R/T1968R/T Offline OP
New York
I was taking apart a 67 440 HP and found this strange fitting. Has provision for a sending unit and a mechanical gauge. Is this a stock piece? Thread broke off the bottom, but I can braze a new one back on it.
Re: Strange oil pressure sender fitting! [Re: R/T1968R/T] #2756665
03/27/20 10:17 PM
03/27/20 10:17 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You could just go to the hardware store and buy a new brass fitting.
Re: Strange oil pressure sender fitting! [Re: stumpy] #2756668
03/27/20 10:31 PM
03/27/20 10:31 PM
Maryland
MoparMike1974 Offline
Maryland
Aftermarket im pretty sure. There looks to be enough meat on it to drill and tap some new 18" NPT threads and put in a brass close nipple.
Re: Strange oil pressure sender fitting! [Re: MoparMike1974] #2756912
03/28/20 03:17 PM
03/28/20 03:17 PM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
Not everyone knows there are two openings on a 440 for oil pressure gauge and idiot light, that gizmo is a hardware store T
Re: Strange oil pressure sender fitting! [Re: MO_PA] #2756916
03/28/20 03:33 PM
03/28/20 03:33 PM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
Look at the mopar cop cars oil system you will find similar things.
STOP POTATO HATE!
Re: Strange oil pressure sender fitting! [Re: Mr PotatoHead] #2756942
03/28/20 04:37 PM
03/28/20 04:37 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
I always install a 'T' when putting an oil pressure gauge on a car/truck with the Idiot light to keep both.
My 84 Shelby had one from the factory. I think all Ralley Dash cars from the 1980's did.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: Strange oil pressure sender fitting! [Re: Dave_J] #2756944
03/28/20 04:43 PM
03/28/20 04:43 PM
A727Tflite Offline
A727Tflite  Offline
Every truck or car that I have seen equipped with dual sending units always had a steel adapter, never brass.
Most of the times it’s been a square block with threads on the end and on one side.
Re: Strange oil pressure sender fitting! [Re: A727Tflite] #2756946
03/28/20 04:46 PM
03/28/20 04:46 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Some Imperials came with the 2 fittings in the back used.D side was gauge Pass side was what was called signal sentry.I had 3 Imps with it When say gas was low oil press dropped temp was hot.The Signal Sentry red light would come on.Rocky
Chrysler Firepower
Re: Strange oil pressure sender fitting! [Re: therocks] #2757509
03/30/20 09:45 AM
03/30/20 09:45 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
If I remember right big blocks and Hemis had 2 holes in the block where the op gauge or sensor is.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Strange oil pressure sender fitting! [Re: hemi-itis] #2757554
03/30/20 11:33 AM
03/30/20 11:33 AM
moparx Offline
moparx  Offline
correct.
beer
Re: Strange oil pressure sender fitting! [Re: hemi-itis] #2757555
03/30/20 11:34 AM
03/30/20 11:34 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Yes, BB has 2 pressure ports.
That Y would be nice on a SB, which only has one port.
