Strange oil pressure sender fitting! #2756634
03/27/20 08:58 PM
03/27/20 08:58 PM
New York
R/T1968R/T Offline OP
New York
I was taking apart a 67 440 HP and found this strange fitting. Has provision for a sending unit and a mechanical gauge. Is this a stock piece? Thread broke off the bottom, but I can braze a new one back on it.
Re: Strange oil pressure sender fitting! [Re: R/T1968R/T] #2756665
03/27/20 10:17 PM
03/27/20 10:17 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You could just go to the hardware store and buy a new brass fitting.
Re: Strange oil pressure sender fitting! [Re: stumpy] #2756668
03/27/20 10:31 PM
03/27/20 10:31 PM
Maryland
MoparMike1974 Offline
Maryland
Aftermarket im pretty sure. There looks to be enough meat on it to drill and tap some new 18" NPT threads and put in a brass close nipple.
Re: Strange oil pressure sender fitting! [Re: MoparMike1974] #2756912
03/28/20 03:17 PM
03/28/20 03:17 PM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
Not everyone knows there are two openings on a 440 for oil pressure gauge and idiot light, that gizmo is a hardware store T
Re: Strange oil pressure sender fitting! [Re: MO_PA] #2756916
03/28/20 03:33 PM
03/28/20 03:33 PM
Super Spudsville
Mr PotatoHead Online rolleyes
Half Baked
Mr PotatoHead  Online Rolleyes
Half Baked
Super Spudsville
Look at the mopar cop cars oil system you will find similar things.
STOP POTATO HATE!
Re: Strange oil pressure sender fitting! [Re: Mr PotatoHead] #2756942
03/28/20 04:37 PM
03/28/20 04:37 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
I always install a 'T' when putting an oil pressure gauge on a car/truck with the Idiot light to keep both.
My 84 Shelby had one from the factory. I think all Ralley Dash cars from the 1980's did.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: Strange oil pressure sender fitting! [Re: Dave_J] #2756944
03/28/20 04:43 PM
03/28/20 04:43 PM
A727Tflite Offline
A727Tflite  Offline
Every truck or car that I have seen equipped with dual sending units always had a steel adapter, never brass.
Most of the times it’s been a square block with threads on the end and on one side.
Re: Strange oil pressure sender fitting! [Re: A727Tflite] #2756946
03/28/20 04:46 PM
03/28/20 04:46 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Some Imperials came with the 2 fittings in the back used.D side was gauge Pass side was what was called signal sentry.I had 3 Imps with it When say gas was low oil press dropped temp was hot.The Signal Sentry red light would come on.Rocky
Chrysler Firepower
Re: Strange oil pressure sender fitting! [Re: therocks] #2757509
03/30/20 09:45 AM
03/30/20 09:45 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
If I remember right big blocks and Hemis had 2 holes in the block where the op gauge or sensor is.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Strange oil pressure sender fitting! [Re: hemi-itis] #2757554
03/30/20 11:33 AM
03/30/20 11:33 AM
moparx Offline
moparx  Offline
correct.
beer
Re: Strange oil pressure sender fitting! [Re: hemi-itis] #2757555
03/30/20 11:34 AM
03/30/20 11:34 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yes, BB has 2 pressure ports.
That Y would be nice on a SB, which only has one port.
