Max Wedge oil pan #2756274
03/26/20 07:46 PM
03/26/20 07:46 PM
NW Indiana
P
powertrip Offline OP
P
NW Indiana
Does anybody know what the sump depths are for the Max Wedge and '66 to '69 Hemi oil pans are?
Tried calling Mancini, they are down to a skeleton staff and can't readily pull them from the shelves for measurement.
Looking for options that will fit my '65 Dodge Coronet RB.
Re: Max Wedge oil pan [Re: powertrip] #2756303
03/26/20 09:56 PM
03/26/20 09:56 PM
The best working and fit is the 1966 to 1969 street hemi oil pan, been there done that swap on a bunch of 1963 to 1965 B body street drag and race only cars up
Those pans are about 1 to 2.0 inches deeper than the original air sucking swinging pick up long sump M.W. oil pans on the OEM M.W. motors.
I think a 3/8 NPT stock oil pickup for a 1965 to 1970 C body B-R/B motor will fit and work good up scope
If your block has been modded for the larger 1/2 NPT then use the stock street Hemi oil pick up up
Re: Max Wedge oil pan [Re: Cab_Burge] #2756346
03/26/20 11:35 PM
03/26/20 11:35 PM
Wi.
old_racer Offline
old_racer  Offline
Wi.
I have a 66 hemi pan on my 63 max wedge clone, and it hangs below the k=member at least an inch or so.
Re: Max Wedge oil pan [Re: old_racer] #2756532
03/27/20 04:22 PM
03/27/20 04:22 PM
NW Indiana
P
P
NW Indiana
That helps, I have a deep sump Milodon that hung down about 3", I shortened the sump 2", but now it only holds 4 quarts of oil to the baffle. The only negative I've read about the Max Wedge pan is you have to modify it to fit a windage tray.
I have an issue spending $300 on a pan only to have to blacksmith it. hammer
Re: Max Wedge oil pan [Re: powertrip] #2756556
03/27/20 05:25 PM
03/27/20 05:25 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I used the Milodon street HEMI pan and it barely fits the stock K-frame.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Max Wedge oil pan [Re: fourgearsavoy] #2756603
03/27/20 07:29 PM
03/27/20 07:29 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I made the K frame so ANY pan will fit up
Now I can get to the bolts going into the timing cover with a straight extension wink
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Max Wedge oil pan [Re: fourgearsavoy] #2756691
03/28/20 01:20 AM
03/28/20 01:20 AM
NW Indiana
P
P
NW Indiana
Gus beer
I've tried the '70-'71 Hemi pan, it definitely hits the K-frame pretty hard, not gonna work.
Re: Max Wedge oil pan [Re: hemi-itis] #2756696
03/28/20 01:28 AM
03/28/20 01:28 AM
NW Indiana
P
P
NW Indiana
That's one solution, but not keeping with the "Day 2" flavor of the car.
That is why I'm trying to find the sump depth of the Max Wedge and ''66-'69 Hemi pans.
Re: Max Wedge oil pan [Re: Cab_Burge] #2756698
03/28/20 01:30 AM
03/28/20 01:30 AM
NW Indiana
P
P
NW Indiana
Cab, do you know how many quarts those pans hold in the sump up to the baffle?
Re: Max Wedge oil pan [Re: powertrip] #2756884
03/28/20 02:13 PM
03/28/20 02:13 PM
No I don't, sorry confused I put 5 quarts in them plus one for the stock oil filter up
I like and use the stock 1970-71 6 quart Hemi and six pack oil pans on all my motors that pan will fit in the owners cars up It is shallower and longer on the sump so it probably won't fit into a early B body with the stock K member and motor mounts, but maybe it will scope
I have a 1963 Plymouth Fury that I'm going to build for myself, I bought a 1966 to 1971 B body V8 K member for it so I can use that oil pan, that slides the motor back about a 1.5 inches and down lower in the chassis also and looks stock to most people also devil
Re: Max Wedge oil pan [Re: Cab_Burge] #2756931
03/28/20 04:11 PM
03/28/20 04:11 PM
A727Tflite Offline
A727Tflite  Offline
Standard maxwedge pan takes 4 quarts to the baffles.
For the street add 1 quart for the filter to those 4 as a minimum. That is after your first oil change since a new engine will “use up” at least a quart filling all the passages. That’s the least I would use to tool around with.
For track use I would add 4 + 1 + 2. 4 in the sump, 1 for the filter and 2 that are in suspension at high engine speed. Better more ( 1 quart) than less as long as you have a windage tray in it.
As for using a Hemi pan I have one on my 62 and with the standard k frame it just touches on the passenger side radius of the k frame to the pass side front of the sump. I would take that radius of the k frame and remove it as much as you can staying away from the spot welds of the k frame.
Re: Max Wedge oil pan [Re: powertrip] #2756981
03/28/20 07:05 PM
03/28/20 07:05 PM
AndyF Offline
AndyF  Offline
Is your engine in the stock location for a 1965 B body car? If so you'll have limited options.
Re: Max Wedge oil pan [Re: AndyF] #2757010
03/28/20 08:35 PM
03/28/20 08:35 PM
A727Tflite Offline
A727Tflite  Offline
There are great options if you follow what has been said already.
Re: Max Wedge oil pan [Re: A727Tflite] #2757080
03/29/20 03:11 AM
03/29/20 03:11 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
On my 63 Sport Fury with the stock K-frame I use a Moroso 7 qt pan. It fits with no mods at all. Ron
Re: Max Wedge oil pan [Re: Cab_Burge] #2757233
03/29/20 02:05 PM
03/29/20 02:05 PM
NW Indiana
P
P
NW Indiana
My car has the original '65 k-frame, and I have tried the six pack / Hemi pan, will not fit without major modification.
Using a later k-frame is a great idea, but my headers, exhaust system, driveshaft, etc., are all set up for the original location.
Re: Max Wedge oil pan [Re: powertrip] #2757241
03/29/20 02:19 PM
03/29/20 02:19 PM
My car was completely strip for painting inside and out so I can put it back the way I want it up
this stupid car has a 1962 K member in it that is allowing the steering to rub on the torsion bars really bad so that is one of the reasons to swap it out for a later one, there are a lot better and cheaper choices on headers also for the 1966 to 1972 B and E body cars up
I'm hoping to start on putting it back together this fall or winter after finishing my 1940 Ford Tudor luck
Re: Max Wedge oil pan [Re: A727Tflite] #2757245
03/29/20 02:23 PM
03/29/20 02:23 PM
NW Indiana
P
P
NW Indiana
That's the info I'm looking for. up
I have run the 7 quart Moroso, it fits fine, but I did not like how far down below the k-frame it hangs. So I shortened the sump, and now it only holds 4 quarts to the baffles.
Re: Max Wedge oil pan [Re: 383man] #2757250
03/29/20 02:34 PM
03/29/20 02:34 PM
NW Indiana
P
P
NW Indiana
Thanks to everyone for the information.
My plan now is to take Transmans advice, I will use the modified Moroso and add the extra quarts, as long as the level stays below the windage tray. wrench
Re: Max Wedge oil pan [Re: powertrip] #2761363
04/08/20 06:27 AM
04/08/20 06:27 AM
Melbourne
O
ossietim Offline
ossietim  Offline
O
Melbourne
Standard Max Wedge pan with a 3 Quart accumulator .
Re: Max Wedge oil pan [Re: ossietim] #2761425
04/08/20 10:51 AM
04/08/20 10:51 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
It appears back in the day there were plenty of spun bearings with Max Wedges. I'd opt for a better pan. The closest spot is usually the RF inner flange of the K frame. I've had good success trimming the flange out in that corner. Many times it will make the difference between go and no go. Personally I'll never build another car without a enlarged K-frame. Even with my steering linkage going thru the pan and a diaper the pan comes off in 30 minutes.
Doug
