Demon with S/S springs. Shocks? Brake line? #2747243
02/27/20 10:56 PM
02/27/20 10:56 PM
Wisconsin
wkroncke17 Offline OP
Wisconsin
Running S/S springs on my ‘72 Demon.
I know Mopar Performance makes the long shock for the rear - does anyone make a long aluminum bodied shock (such as QA1) that is adjustable?
ALlso, do I need a longer flexible brake hose for the rear since the SS springs lift the body away from the axle?
Thanks all!
Wally.
Re: Demon with S/S springs. Shocks? Brake line? [Re: wkroncke17] #2747255
02/27/20 11:46 PM
02/27/20 11:46 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
You could dearch your SS springs. Then use a stiff shock to control the lift.
If the lift is uncontrolabled, the tire will unload.
Re: Demon with S/S springs. Shocks? Brake line? [Re: wkroncke17] #2747307
02/28/20 10:09 AM
02/28/20 10:09 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Thanks all!
Wally.
Yes, everyone out there makes longer shocks. I'd recommend you call them and talk to a tech to get the proper part numbers for this.
yes, you want a longer flex hose as the SS springs will create even more separation under accelleration than they already do sitting there.
Re: Demon with S/S springs. Shocks? Brake line? [Re: TC@HP2] #2747338
02/28/20 11:44 AM
02/28/20 11:44 AM
Wisconsin
Wisconsin
Thanks all!
Wally.
TC!
That's what I was assuming, thank you for verifying!
