Running S/S springs on my ‘72 Demon.
I know Mopar Performance makes the long shock for the rear - does anyone make a long aluminum bodied shock (such as QA1) that is adjustable?
ALlso, do I need a longer flexible brake hose for the rear since the SS springs lift the body away from the axle?
Thanks all!
Wally.
Yes, everyone out there makes longer shocks. I'd recommend you call them and talk to a tech to get the proper part numbers for this.
yes, you want a longer flex hose as the SS springs will create even more separation under accelleration than they already do sitting there.
