CARB SOAK #2745339
02/21/20 11:44 PM
02/21/20 11:44 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
Hey guys, ..anyone have an alternative to the big gallon of solvent---the stuff you soak carburetor parts in ??
Im guessing someone has came up with a home-brew concoction that works good ??
Re: CARB SOAK [Re: 493_DART] #2745343
02/22/20 12:08 AM
02/22/20 12:08 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Nothing works as good as the old stuff, MEK. Not available for consumer use anymore.
Problem was it can't tell the difference between carburetor gunk and humans.
It could make the nastiest, grimiest carb look like new again tho.
Kevin
Re: CARB SOAK [Re: Twostick] #2745366
02/22/20 01:13 AM
02/22/20 01:13 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I will tell you what I use now. I bought an ultrasonic cleaner from ebay, and I use a solution of water, aluminum wheel cleaner and purple power cleaner. 15 minutes and the carb is as clean as it is going to get. Rinse it in water, and blow dry. No stink, and it seems to clean very well. The ultrasoni cleaner is also great for small parts like bolts, rocker arms, rods, etc. The only issue with carbs is, that if you leave a carb in too long, it can lossen the lead plugs in a carb, so don't over do it.
https://www.ebay.com/itm/ALLSTAR-PERFORMANCE-Ultrasonic-Cleaner-Small-1-Gallon-Capacity-ALL10640/233489618516?hash=item365d10d654:g:aMkAAOSwdnNePwqt
Re: CARB SOAK [Re: jwb123] #2745372
02/22/20 02:47 AM
02/22/20 02:47 AM
Washington
skrews Offline
skrews  Offline
Washington
Always wanted to try acetone. No idea if any good as carb cleaner though.
Re: CARB SOAK [Re: skrews] #2745475
02/22/20 01:12 PM
02/22/20 01:12 PM
there are some good utube vids on this, one used a HF sonic cleaner & the simple green (aluminum) formula.
Re: CARB SOAK [Re: 493_DART] #2745601
02/22/20 09:04 PM
02/22/20 09:04 PM
New York
64 Sportfury Offline
New York
Edelbrock recommends parts cleaner or lacquer thinner. I just did one in lacquer thinner. Came out great.
Re: CARB SOAK [Re: 493_DART] #2745701
02/23/20 10:51 AM
02/23/20 10:51 AM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
You guys using chemicals, like lacquer thinner need to protect your asses...Wear gloves and the proper respirator with the corresponding cartridge.
Bare skin and cloth masks...Uh oh.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: CARB SOAK [Re: Adobedude] #2746561
02/25/20 10:24 PM
02/25/20 10:24 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Barrymans B12 is the best, add a little methelene chloride and you are good to go, put a little glycol on the top to keep any stink out of your shop. MEK evaporates too fast. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: CARB SOAK [Re: astjp2] #2746926
02/27/20 12:28 AM
02/27/20 12:28 AM
East Coast
A/MP Offline
A/MP  Offline
East Coast
painters gun and brush cleaner. In a metal 5 gallon pail and let it soak for days. Softens polyester and epoxy paints. Just like any product, temp is key. Keep it off the cold floor. Workbench top helps.
Re: CARB SOAK [Re: jwb123] #2746978
02/27/20 09:20 AM
02/27/20 09:20 AM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
This is what I am about to do for our shop. We are looking at trying to find the right size (and quality) ultrasonic cleaner for fasteners and carbs. Thought about buying a tumbler as well, to provide a nice finish on nuts and bolts and fasteners after ultrasonic cleaning.
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: CARB SOAK [Re: ChrgrCuda] #2747328
02/28/20 11:09 AM
02/28/20 11:09 AM
East Coast
A/MP Offline
A/MP  Offline
East Coast
Ultrasonics do a great job. Import machines don't hold up that well. Their beat drops due to cheaper components. You need a large enough machine to be able to sunmerge the complete body. That now starts to get costlly. Check with stateside manufacturer of solutions for the best choice for product selection. If this is a 1 shot deal, solvent claening is the best overall choice..
