Originally Posted by 493_DART
Hey guys, ..anyone have an alternative to the big gallon of solvent---the stuff you soak carburetor parts in ??
Im guessing someone has came up with a home-brew concoction that works good ??
Nothing works as good as the old stuff, MEK. Not available for consumer use anymore.
Problem was it can't tell the difference between carburetor gunk and humans.
It could make the nastiest, grimiest carb look like new again tho.
Kevin
