Acceptable spring pressures with 2 and 4 groove locks #2744675
02/19/20 05:31 PM
02/19/20 05:31 PM
Tucson AZ,
MadMopars Offline OP
Tucson AZ,
My question is basically this... At what spring pressure do you need to get away from the 2 and 4 groove valve locks? I'm about to install a set of Isky 8005A springs at 1.85" with around .540 lift. Should be about 375# on the nose although I need to confirm that. That being said, are the 2 and 4 groove Comp locks a bad idea? Anyone else running the 2 and 4 groove locks with the higher spring pressures? Just trying to decide if I need to bite the bullet and get some Ferrea valves heading this way at some point... As always, appreciate the help! -Trent
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: Acceptable spring pressures with 2 and 4 groove locks [Re: MadMopars] #2744743
02/19/20 09:04 PM
02/19/20 09:04 PM
If your going to have less than 600Lb.opened don't worry twocents
If your wanting to rev it over 7000 RPM buy all new GOOD valve up
Re: Acceptable spring pressures with 2 and 4 groove locks [Re: Cab_Burge] #2744752
02/19/20 09:21 PM
02/19/20 09:21 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
factory 2 piece valves?
Re: Acceptable spring pressures with 2 and 4 groove locks [Re: lewtot184] #2744791
02/19/20 10:45 PM
02/19/20 10:45 PM
Tucson AZ,
Tucson AZ,
That's a possibility... Although, I believe they were replaced at one point they do look similar to a factory valve in design. Assuming that's the case, does that become a high risk at these pressures? shruggy
Re: Acceptable spring pressures with 2 and 4 groove locks [Re: Cab_Burge] #2744794
02/19/20 10:52 PM
02/19/20 10:52 PM
Tucson AZ,
Tucson AZ,
Cab, These are going on the 413 with that old school Crower cam (105LSA). If I shift it above 6000 RPM it would probably only be because I missed a gear. I don't see it being a high RPM motor, at least not intentionally... Lol.
Re: Acceptable spring pressures with 2 and 4 groove locks [Re: MadMopars] #2744796
02/19/20 11:02 PM
02/19/20 11:02 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
those are 2 piece. i'd be afraid of popping the head off of them with modern springs and lobes. I use one piece on everything anymore; although a 2 piece will work ok in some of the milder builds . the ferrea 5000 series valves aren't expensive and should be pretty safe for what your doing.
Re: Acceptable spring pressures with 2 and 4 groove locks [Re: lewtot184] #2744946
02/20/20 02:25 PM
02/20/20 02:25 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: Acceptable spring pressures with 2 and 4 groove locks [Re: John_Kunkel] #2744948
02/20/20 02:28 PM
02/20/20 02:28 PM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
Thats good info, I had always wondered the limitations, but im afraid I will continue with F5000-s on everything mild.
If a oem valve popped off at 2k or even idel id be the one it happens to. Im not that lucky.
STOP POTATO HATE!
Re: Acceptable spring pressures with 2 and 4 groove locks [Re: Mr PotatoHead] #2744949
02/20/20 02:30 PM
02/20/20 02:30 PM
I've bent more valves form over revving them than I have had break work shruggy
Re: Acceptable spring pressures with 2 and 4 groove locks [Re: Cab_Burge] #2745488
02/22/20 01:47 PM
02/22/20 01:47 PM
Tucson AZ,
Tucson AZ,
So, after soaking on it for a few days, I wish I had bought new valves from day one. However, I think I'm going to go ahead and assemble the heads with the valves I have and leave the inner springs out for the cam break in. Reason being, before I can really even beat on the truck I am supposed to follow McLeods break procedure for the new clutch, although that's a whole other debate... I also need to finish building the Dana to take the place of one legged 9". Suffice to say, it'll be a bit before I get to really start beating on the thing. When the time comes to put the inner springs back in, I may swap out the valves worth a set of Ferreas. Until then, I'm going to try to keep making forward progress on the thing so I go back to moving it around under its own power and stop pushing the damn thing around. Lol.
