Re: Acceptable spring pressures with 2 and 4 groove locks
[Re: Cab_Burge]
#2744752
02/19/20 09:21 PM
02/19/20 09:21 PM
Posts: 3,913 usa
lewtot184
usa
[Re: John_Kunkel]
#2744948
02/20/20 02:28 PM
02/20/20 02:28 PM
Posts: 9,294 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Thats good info, I had always wondered the limitations, but im afraid I will continue with F5000-s on everything mild.
If a oem valve popped off at 2k or even idel id be the one it happens to. Im not that lucky.
STOP POTATO HATE!
[Re: Cab_Burge]
#2745488
02/22/20 01:47 PM
02/22/20 01:47 PM
Posts: 1,289 Tucson AZ,
MadMopars
Tucson AZ,
So, after soaking on it for a few days, I wish I had bought new valves from day one. However, I think I'm going to go ahead and assemble the heads with the valves I have and leave the inner springs out for the cam break in. Reason being, before I can really even beat on the truck I am supposed to follow McLeods break procedure for the new clutch, although that's a whole other debate... I also need to finish building the Dana to take the place of one legged 9". Suffice to say, it'll be a bit before I get to really start beating on the thing. When the time comes to put the inner springs back in, I may swap out the valves worth a set of Ferreas. Until then, I'm going to try to keep making forward progress on the thing so I go back to moving it around under its own power and stop pushing the damn thing around. Lol.
