Re: Mechanical roller lifter
[Re: fast68plymouth]
#2750253
03/08/20 08:08 PM
03/08/20 08:08 PM
Posts: 108 WNY
Moparrob68
WNY
Lifter to bushing clearance = 0.002 The EDM oil feed is on the side of the lifter 90* from the roller same as the comp What is the body height of the 87016c ? they look short My Crower 66233E are 1.950 body height and they still sit 0.500 does in the bushing and hang over 0.500 below the bushing Have you used the comp 96829-16 Sportsman lifters? they look taller in the online catalog if that means anything
[Re: Moparrob68]
#2750406
03/09/20 10:55 AM
03/09/20 10:55 AM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
On the 87016, from the bottom of the wheel to the top of the body is 1.810”.
From the bottom of the wheel to the center of the link bar attaching screw is about 3.050”. They are designed to be able to be used with blocks that have tall lifter bores. I used them in a World aluminum block with a .484 lobe lift cam.
Here is a pic of an Isky Red Zone that has the flats on the sides of the body like yours. They have the EDM holes done the same as well........ but they have added an oil band to get the oil from the gallery to the EDM holes.
As you’ve discovered....... without “connecting the dots”...... the EDM holes aren’t much help.
I have a few customers running the Sportsman lifters with no problems, but they are all running stock blocks. However, I don’t think there would be any issue running them in a block set up like yours. For the BB Mopar application, they do not pushrod oil.
[Re: dafixr]
#2750519
03/09/20 04:45 PM
03/09/20 04:45 PM
Posts: 714 Lake Villa Il
INTMD8
Lake Villa Il
The Morels I posted have pushrod oiling
[Re: INTMD8]
#2750721
03/10/20 11:38 AM
03/10/20 11:38 AM
Posts: 279 Chicago land, IL
dafixr
Chicago land, IL
do you have Morel part# ? Thanks (5260)?
[Re: AndyF]
#2752921
03/17/20 07:39 PM
03/17/20 07:39 PM
Posts: 630 Ct
Wirenut
Ct
I ran into this a couple of times where Comp published information saying the 829 provided oil to the bearing but it doesn't. I think someone at Comp just messed up and got their part numbers confused. The issue is that then people read that info and believe it and then other folks don't know what to believe. Just received my 829s they do have pin oiling holes one on each side within the very narrow oil band . .690 lift and the band stays well within the lifter bore . Have not measured that yet but will try G
[Re: Wirenut]
#2753033
03/18/20 09:29 AM
03/18/20 09:29 AM
fast68plymouth
So. Burlington, Vt.
Any way you could post a pic of these?
They are straight “829’s”....... not 96829’s, correct?
In the past, 829’s have had smooth bodies without any oil band.
Top- 829
Bottom- 96829
[Re: dafixr]
#2753043
03/18/20 10:04 AM
03/18/20 10:04 AM
INTMD8
Lake Villa Il
do you have Morel part# ? Thanks (5260)? The ones I have are #6774
[Re: '72CudaRacer]
#2753061
03/18/20 10:33 AM
03/18/20 10:33 AM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
If you want a good durable lifter, go w/ the Iskys w/ the bushings. I have the old style Isky Red Zones w/ needle bearings and they've been flawless. Bought them in 2006 before the EZ Roll option was available. Another small detail on the Redzone lifters,,,,,they hit the thicker lifter bore on the megablock I am following this thread closely, I am building a Mega block for a customer now that has always run a solid flat tappet cam but wants to go to a solid roller cam this time. The Isky Red Zone lifters are on the short list for now. What part of the lifter is hitting the lifter bore? I am assuming the link bar? Is it because the lifter is too short? Any other things to be concerned about? Also what advantage is the AMC lifter over the Mopar(besides the pin oiling)? Thanks, Brian Yes,the link bars hit the lifter boss so the wheel did not hit the cam lobe.
#2753181
03/18/20 03:50 PM
03/18/20 03:50 PM
Posts: 630 Ct
Wirenut
Ct
Top- 829
Bottom- 96829 Apologies they are 96829 as shown in your pic.
