Steering Stability #2739480
02/03/20 11:14 PM
02/03/20 11:14 PM
Mesa, Arizona
dart4forte Offline OP
Mesa, Arizona
The truck is a 74 stepside. It’s been lowered via van LCAs. Been experiencing a wobble at around 35mph and smooths out. Someone along the life of the truck welded some angle iron from the frame in vicinity of the steering box to the core support. Looks like they were trying to address the stress the box puts on the frame. I’m thinking of cutting out that ankle iron bracing and add the correct brace from the steering box to the core support. Also thinking of adding a brace that ties the left and right stub. Anyone else deal with this and what did you do?
Abe Lincoln
Re: Steering Stability [Re: dart4forte] #2739661
02/04/20 02:27 PM
02/04/20 02:27 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
That won't cure your death wobble. It's caused by steering geometry being off due to the truck being lowered. Installing the correct brace won't hurt but won't get rid of the wobble. It seems installing a steering shock helps. Do an online search for death wobble fixs.
Re: Steering Stability [Re: stumpy] #2739684
02/04/20 03:22 PM
02/04/20 03:22 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
A steering shock is just a band aid for a geometry problem.
If you haven't aready you need to take the truck to a good reputable alignment guy, not a tire shop and have the alignment checked.
68 Barracuda Formula S 340
Re: Steering Stability [Re: stumpy] #2739694
02/04/20 03:45 PM
02/04/20 03:45 PM
North East USA
BIGGERED Offline
Reasonable Title
BIGGERED  Offline
Reasonable Title
North East USA
The only vehicle I experienced death wobble in was a Jeep ZJ, there was no way to drive out of it, only slowing down to an almost stop. I recall a ZJ passing me at 65 MPH going into death wobble and I witnessed the left and right tires alternately leaving the road surface completely. The first time that happened to me I needed to go home and change my drawers. It was an extremely violent unpleasant event. Ultimately traced to worn factory and then a cheap aftermarket track bar.Granted the ZJ was 4WD but had a complete front end rebuild including ball joints
I think the 1974 frame is significantly different from a later 70's frame but recall the late seventies frames cracking at the box/frame connection hence the creation of the steering box brace that came with a recall. This defect appeared to be exacerbated by running 7-8" wide wheel and tires on the front of a D100/D150 2 WD truck.
When I was planning a Lil Red and a Warlock restoration my plan was to fully box the front left frame rail at a minimum but I am no mechanical genius.
I know you have posted a lot regarding this truck, is the front end and suspension all new high quality parts? Do you see any cracking in the frame rail?
Good luck!
Red
Re: Steering Stability [Re: BIGGERED] #2739715
02/04/20 05:43 PM
02/04/20 05:43 PM
Mesa, Arizona
Mesa, Arizona
Good luck!
Red
The front suspension is all fresh MOOG to include the inner tie rods and drag link. Fresh Red Head steering box, fresh shocks. I am running 15x7 slots in the front with 255/60/15. When we had the old box off we checked for cracking. The alignment is dead on. We also did the axle flip replacing the Dana with 8.75. I like your idea of boxing the frame.
Abe Lincoln
Re: Steering Stability [Re: dart4forte] #2739721
02/04/20 06:26 PM
02/04/20 06:26 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
What is the caster and camber set at now?
Re: Steering Stability [Re: NITROUSN] #2739723
02/04/20 06:32 PM
02/04/20 06:32 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I lowered my 74 D100 using Dakota drop spindles and rear axle flip and the alignment specs were different then stock. I got the specs from one of the Dodge truck sites but it's been a few years so I don't remember which site it was. I had the same wobble problem so I do have some experience with it.
Re: Steering Stability [Re: stumpy] #2739730
02/04/20 06:45 PM
02/04/20 06:45 PM
Mesa, Arizona
Mesa, Arizona
What year spindles did you use, any pics?
Abe Lincoln
Re: Steering Stability [Re: dart4forte] #2739731
02/04/20 06:50 PM
02/04/20 06:50 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I think they were first gen Dakotas form bell tech. Got the complete kit with shocks and all. Ended up 2" drop in front and 4" in the rear. Did have to swap rotors because of bearing sizes. I did this 10 years ago so my memory isn't perfect.
Re: Steering Stability [Re: dart4forte] #2739749
02/04/20 08:08 PM
02/04/20 08:08 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
I'd put a little more caster in it...
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Steering Stability [Re: W.I.N. Racing] #2739754
02/04/20 08:19 PM
02/04/20 08:19 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Agree
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Steering Stability [Re: W.I.N. Racing] #2739804
02/04/20 10:37 PM
02/04/20 10:37 PM
N
N
That's why I asked the poster to show what it was set to. Without seeing the print out and knowing what it was aligned to its hard to make correct suggestions.
Re: Steering Stability [Re: NITROUSN] #2739820
02/05/20 12:26 AM
02/05/20 12:26 AM
Mesa, Arizona
Mesa, Arizona
I can do that tomorrow
Abe Lincoln
Re: Steering Stability [Re: dart4forte] #2739829
02/05/20 01:29 AM
02/05/20 01:29 AM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
1974 D200 Club cab long box. We used B van LCA's and we moved the rear springs front hanger up and used drop shackles. This was a net effect of dropping this D200 4 inches all around. My son is running 245/70 16's front and 265/70 16 rear. No wobble at any speed. We set the alignment in the driveway using a level for Camber and a string for toe.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: Steering Stability [Re: Dave_J] #2739897
02/05/20 11:11 AM
02/05/20 11:11 AM
Mesa, Arizona
Mesa, Arizona
This is the brace I plan on using
Abe Lincoln
Re: Steering Stability [Re: dart4forte] #2739936
02/05/20 12:36 PM
02/05/20 12:36 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
That's a good piece and will help keep the frame from breaking. Won't stop the wobble.
Re: Steering Stability [Re: stumpy] #2739969
02/05/20 01:38 PM
02/05/20 01:38 PM
Mesa, Arizona
Mesa, Arizona
Kinda figured that
Abe Lincoln
Re: Steering Stability [Re: dart4forte] #2739977
02/05/20 01:47 PM
02/05/20 01:47 PM
Kirkland, Washington
Pacnorthcuda Offline
Kinda figured that
Is your truck 4wd? If so, inspect the front track bar for slop very carefully.
Re: Steering Stability [Re: Pacnorthcuda] #2739988
02/05/20 02:16 PM
02/05/20 02:16 PM
N
N
Kinda figured that
Track bars did not come out until 1994.
Re: Steering Stability [Re: NITROUSN] #2740089
02/05/20 07:09 PM
02/05/20 07:09 PM
Byron, NY
Byron, NY
More caster will increase steering feel (harder) less caster will decrease steering feel (less effort) and create steering instability. As the axis inclination angle increased the ability to pivot about that axis becomes easier and more susceptible to road condition influences. Most factory specs are a compromise between optimal and driver effort. More caster reduces road condition influences. Once you modify a suspension factory specs are just a jumping off point with tweaks to follow twocents
'60 Willys CJ5
