I'd put a little more caster in it... That's why I asked the poster to show what it was set to. Without seeing the print out and knowing what it was aligned to its hard to make correct suggestions. More caster will increase steering feel (harder) less caster will decrease steering feel (less effort) and create steering instability. As the axis inclination angle increased the ability to pivot about that axis becomes easier and more susceptible to road condition influences. Most factory specs are a compromise between optimal and driver effort. More caster reduces road condition influences. Once you modify a suspension factory specs are just a jumping off point with tweaks to follow
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
