I have the front end up and plan to check the front wheel bearings and swap tires. I pretty much ruled out an out of round wheel in that when they were balanced a wheel is sure would of showed up. Yeah a wheel would have showed up but may still balance OK. Maybe the guy operating the balancer didn't give [censored]. A broken belt in a tire may not have shown up or refer back to the original guy running the balancer. I seriously doubt that since your issue only manifests at a certain speed ( and a low speed at that) and then clears up that you have an alignment issue.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
