Steering Stability
#2739480
02/03/20 11:14 PM
02/03/20 11:14 PM
Posts: 16,146 Mesa, Arizona
dart4forte
Mesa, Arizona
The truck is a 74 stepside. It’s been lowered via van LCAs. Been experiencing a wobble at around 35mph and smooths out. Someone along the life of the truck welded some angle iron from the frame in vicinity of the steering box to the core support. Looks like they were trying to address the stress the box puts on the frame. I’m thinking of cutting out that ankle iron bracing and add the correct brace from the steering box to the core support. Also thinking of adding a brace that ties the left and right stub. Anyone else deal with this and what did you do?
Abe Lincoln
Re: Steering Stability
[Re: stumpy]
#2739684
02/04/20 03:22 PM
02/04/20 03:22 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
A steering shock is just a band aid for a geometry problem.
If you haven't aready you need to take the truck to a good reputable alignment guy, not a tire shop and have the alignment checked.
68 Barracuda Formula S 340
[Re: stumpy]
#2739694
02/04/20 03:45 PM
02/04/20 03:45 PM
Posts: 1,497 North East USA
BIGGERED
Reasonable Title
Reasonable Title
North East USA
That won't cure your death wobble. It's caused by steering geometry being off due to the truck being lowered. Installing the correct brace won't hurt but won't get rid of the wobble. It seems installing a steering shock helps. Do an online search for death wobble fixs. The only vehicle I experienced death wobble in was a Jeep ZJ, there was no way to drive out of it, only slowing down to an almost stop. I recall a ZJ passing me at 65 MPH going into death wobble and I witnessed the left and right tires alternately leaving the road surface completely. The first time that happened to me I needed to go home and change my drawers. It was an extremely violent unpleasant event. Ultimately traced to worn factory and then a cheap aftermarket track bar.Granted the ZJ was 4WD but had a complete front end rebuild including ball joints I think the 1974 frame is significantly different from a later 70's frame but recall the late seventies frames cracking at the box/frame connection hence the creation of the steering box brace that came with a recall. This defect appeared to be exacerbated by running 7-8" wide wheel and tires on the front of a D100/D150 2 WD truck. When I was planning a Lil Red and a Warlock restoration my plan was to fully box the front left frame rail at a minimum but I am no mechanical genius. I know you have posted a lot regarding this truck, is the front end and suspension all new high quality parts? Do you see any cracking in the frame rail? Good luck! Red
[Re: BIGGERED]
#2739715
02/04/20 05:43 PM
02/04/20 05:43 PM
dart4forte
Mesa, Arizona
That won't cure your death wobble. It's caused by steering geometry being off due to the truck being lowered. Installing the correct brace won't hurt but won't get rid of the wobble. It seems installing a steering shock helps. Do an online search for death wobble fixs. The only vehicle I experienced death wobble in was a Jeep ZJ, there was no way to drive out of it, only slowing down to an almost stop. I recall a ZJ passing me at 65 MPH going into death wobble and I witnessed the left and right tires alternately leaving the road surface completely. The first time that happened to me I needed to go home and change my drawers. It was an extremely violent unpleasant event. Ultimately traced to worn factory and then a cheap aftermarket track bar.Granted the ZJ was 4WD but had a complete front end rebuild including ball joints I think the 1974 frame is significantly different from a later 70's frame but recall the late seventies frames cracking at the box/frame connection hence the creation of the steering box brace that came with a recall. This defect appeared to be exacerbated by running 7-8" wide wheel and tires on the front of a D100/D150 2 WD truck. When I was planning a Lil Red and a Warlock restoration my plan was to fully box the front left frame rail at a minimum but I am no mechanical genius. I know you have posted a lot regarding this truck, is the front end and suspension all new high quality parts? Do you see any cracking in the frame rail? Good luck! Red The front suspension is all fresh MOOG to include the inner tie rods and drag link. Fresh Red Head steering box, fresh shocks. I am running 15x7 slots in the front with 255/60/15. When we had the old box off we checked for cracking. The alignment is dead on. We also did the axle flip replacing the Dana with 8.75. I like your idea of boxing the frame.
Abe Lincoln
[Re: stumpy]
#2739730
02/04/20 06:45 PM
02/04/20 06:45 PM
dart4forte
Mesa, Arizona
I lowered my 74 D100 using Dakota drop spindles and rear axle flip and the alignment specs were different then stock. I got the specs from one of the Dodge truck sites but it's been a few years so I don't remember which site it was. I had the same wobble problem so I do have some experience with it. What year spindles did you use, any pics?
Abe Lincoln
[Re: dart4forte]
#2739749
02/04/20 08:08 PM
02/04/20 08:08 PM
Posts: 2,112 Byron, NY
W.I.N. Racing
Byron, NY
I'd put a little more caster in it...
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: NITROUSN]
#2739820
02/05/20 12:26 AM
02/05/20 12:26 AM
dart4forte
Mesa, Arizona
I'd put a little more caster in it... That's why I asked the poster to show what it was set to. Without seeing the print out and knowing what it was aligned to its hard to make correct suggestions. I can do that tomorrow
Abe Lincoln
[Re: dart4forte]
#2739829
02/05/20 01:29 AM
02/05/20 01:29 AM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
1974 D200 Club cab long box. We used B van LCA's and we moved the rear springs front hanger up and used drop shackles. This was a net effect of dropping this D200 4 inches all around. My son is running 245/70 16's front and 265/70 16 rear. No wobble at any speed. We set the alignment in the driveway using a level for Camber and a string for toe.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: Dave_J]
#2739897
02/05/20 11:11 AM
02/05/20 11:11 AM
dart4forte
Mesa, Arizona
This is the brace I plan on using
Abe Lincoln
[Re: stumpy]
#2739969
02/05/20 01:38 PM
02/05/20 01:38 PM
dart4forte
Mesa, Arizona
That's a good piece and will help keep the frame from breaking. Won't stop the wobble. Kinda figured that
Abe Lincoln
[Re: dart4forte]
#2739977
02/05/20 01:47 PM
02/05/20 01:47 PM
Posts: 21,825 Kirkland, Washington
Pacnorthcuda
That's a good piece and will help keep the frame from breaking. Won't stop the wobble. Kinda figured that Is your truck 4wd? If so, inspect the front track bar for slop very carefully.
[Re: NITROUSN]
#2740089
02/05/20 07:09 PM
02/05/20 07:09 PM
W.I.N. Racing
Byron, NY
I'd put a little more caster in it... That's why I asked the poster to show what it was set to. Without seeing the print out and knowing what it was aligned to its hard to make correct suggestions. More caster will increase steering feel (harder) less caster will decrease steering feel (less effort) and create steering instability. As the axis inclination angle increased the ability to pivot about that axis becomes easier and more susceptible to road condition influences. Most factory specs are a compromise between optimal and driver effort. More caster reduces road condition influences. Once you modify a suspension factory specs are just a jumping off point with tweaks to follow
