Re: who has a good quality ladderbar kit for a mopar
[Re: sixpakdodge]
#2736067
01/24/20 11:24 AM
01/24/20 11:24 AM
Posts: 4,682 On the parachute mount
n20mstr
Ive got an S&W ladder bar kit on my Dart for probably 20 years now. I replaced the front heims as they do wear out , but other than that its been a great kit.
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#2736071
01/24/20 11:33 AM
01/24/20 11:33 AM
Posts: 326 Alberta
Wookie316
Alberta
Chassis engineering outlaw bars. More $. But totally worth it with the adjustability they offer.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
[Re: mopar dave]
#2736073
01/24/20 11:46 AM
01/24/20 11:46 AM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
I like the idea of the safety loops. I was thinking you said your car is dead hooking the way it is, ?
[Re: CSK]
#2736076
01/24/20 11:52 AM
01/24/20 11:52 AM
Posts: 20,184 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Pay a few bucks extra for the double adjustable so you don’t have to take them apart to adjust. Then center the adjusters up when you assemble everything so you have room to shorten and lengthen the bars.
[Re: mopar dave]
#2736088
01/24/20 12:14 PM
01/24/20 12:14 PM
Posts: 1,774 Keymar, MD
DusterKid
Keymar, MD
I like the idea of the safety loops. Which ever style you go with make sure they have the safety loops on the front heim joint. I know of 2 local racers that wrecked in the last 2 years due to front heims breaking. Both times the drivers walked away, but both cars were a total loss.
[Re: DusterKid]
#2736164
01/24/20 02:49 PM
01/24/20 02:49 PM
Posts: 11,600 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Money spent on maximum adjustability and strength is money well spent. Coilovers? Decent shocks are also a must.
What is your chassis shop guy recommending?
Backhalving the car? Minitub with stock frame rails? Really, with the systems and parts available for leafs these days, I don't think I would bother with ladders unless I was going to a big tire. Just getting the car lower can be done with leafs. And it can be made to hook.
[Re: CMcAllister]
#2736183
01/24/20 03:41 PM
01/24/20 03:41 PM
Posts: 4,457 Washington
madscientist
Washington
Why ladder bars? If you are using leaf springs a Calvert style bar is just as good. If you are going to coil overs, use a 4 link. A ladder bar is always too short and the IC will always be too high because of how short the bars are.
[Re: madscientist]
#2736194
01/24/20 04:14 PM
01/24/20 04:14 PM
Posts: 20,184 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Why ladder bars? If you are using leaf springs a Calvert style bar is just as good. If you are going to coil overs, use a 4 link. A ladder bar is always too short and the IC will always be too high because of how short the bars are. I have two ladder bar cars and one I hope to be in the low 8’s on caltracks. I agree if I had caltacks I could never See me switching it to a ladder bar car. I know what caltracks are capibile of.
[Re: madscientist]
#2736199
01/24/20 04:40 PM
01/24/20 04:40 PM
Posts: 4,684 Wichita
GY3
Wichita
Why ladder bars? If you are using leaf springs a Calvert style bar is just as good. If you are going to coil overs, use a 4 link. A ladder bar is always too short and the IC will always be too high because of how short the bars are. Exactly! Leaf spring and shock technology has come a long way in the past decade.
