who has a good quality ladderbar kit for a mopar #2736046
01/24/20 10:33 AM
01/24/20 10:33 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Been thinkin about doing a ladder bar and new wheels and tires with a lower stance on my Barracuda. so, just searchin around for a ladderbar kit for an A body. What companies should I be looking at? Thanks
Re: who has a good quality ladderbar kit for a mopar [Re: mopar dave] #2736054
01/24/20 10:53 AM
01/24/20 10:53 AM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Nobody, ladder bars are universal and up to you to configure the installation
Re: who has a good quality ladderbar kit for a mopar [Re: GTS340] #2736055
01/24/20 10:57 AM
01/24/20 10:57 AM
Keymar, MD
DusterKid Online content
DusterKid  Online Content
Keymar, MD
Kits are universal. I've used Competition Engineering ladder bars on 2 of my cars, they do as they are supposed to.
Re: who has a good quality ladderbar kit for a mopar [Re: GTS340] #2736056
01/24/20 10:59 AM
01/24/20 10:59 AM
Mt Morris Michigan
Mt Morris Michigan
Ok, I was looking at the Chris Alston stuff, but i'm not sure of the quality. I want good stuff that doesn't break on the launch like rod ends for instants. This will see mostly street. Over the next few years i'm giving the car a make over for the car shows with a full body wrap as the last thing I do. Thanks
Re: who has a good quality ladderbar kit for a mopar [Re: mopar dave] #2736059
01/24/20 11:08 AM
01/24/20 11:08 AM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
I used a Rick Jones/Quarter Max kit on my '66 Coronet. The design is a little more conducive to not cutting the floor. I ended up buying a lot of RJ/Quartermax stuff after that kit to finish the car. Good stuff. twocents
Re: who has a good quality ladderbar kit for a mopar [Re: sixpakdodge] #2736067
01/24/20 11:24 AM
01/24/20 11:24 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Ive got an S&W ladder bar kit on my Dart for probably 20 years now. I replaced the front heims as they do wear out , but other than that its been a great kit.
....BAD A$$ STREET CAR.....
Re: who has a good quality ladderbar kit for a mopar [Re: n20mstr] #2736071
01/24/20 11:33 AM
01/24/20 11:33 AM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
Chassis engineering outlaw bars. More $. But totally worth it with the adjustability they offer.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: who has a good quality ladderbar kit for a mopar [Re: sixpakdodge] #2736072
01/24/20 11:35 AM
01/24/20 11:35 AM
Mt Morris Michigan
Mt Morris Michigan
I like the idea of the safety loops.
Re: who has a good quality ladderbar kit for a mopar [Re: mopar dave] #2736073
01/24/20 11:46 AM
01/24/20 11:46 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I was thinking you said your car is dead hooking the way it is, ?
Re: who has a good quality ladderbar kit for a mopar [Re: CSK] #2736076
01/24/20 11:52 AM
01/24/20 11:52 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Pay a few bucks extra for the double adjustable so you don’t have to take them apart to adjust. Then center the adjusters up when you assemble everything so you have room to shorten and lengthen the bars.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: who has a good quality ladderbar kit for a mopar [Re: mopar dave] #2736088
01/24/20 12:14 PM
01/24/20 12:14 PM
Keymar, MD
Keymar, MD
Which ever style you go with make sure they have the safety loops on the front heim joint. I know of 2 local racers that wrecked in the last 2 years due to front heims breaking. Both times the drivers walked away, but both cars were a total loss.
Re: who has a good quality ladderbar kit for a mopar [Re: CSK] #2736100
01/24/20 01:03 PM
01/24/20 01:03 PM
Mt Morris Michigan
Mt Morris Michigan
Yes, the caltracs are doing their job. Being its an on going project I feel its time for a face lift and I think the ladders are more appropriate for a pro street deal. This car has a full interior and is multi purpose. Shows, cruising and some test and tune track time.
Re: who has a good quality ladderbar kit for a mopar [Re: pittsburghracer] #2736101
01/24/20 01:04 PM
01/24/20 01:04 PM
Mt Morris Michigan
Mt Morris Michigan
great advise and will do. I will be having a chassis shop perform the install. I don't trust my welding with my 110mig. Piece of mind is grand.
Re: who has a good quality ladderbar kit for a mopar [Re: DusterKid] #2736103
01/24/20 01:06 PM
01/24/20 01:06 PM
Mt Morris Michigan
Mt Morris Michigan
My thinking as well. safety safety safety.
Re: who has a good quality ladderbar kit for a mopar [Re: mopar dave] #2736149
01/24/20 02:17 PM
01/24/20 02:17 PM
Keymar, MD
Keymar, MD
If you already have caltracs and they work I wouldn't spend the $$ to change over to ladder bars, esp if you street drive the car, just my twocents
Re: who has a good quality ladderbar kit for a mopar [Re: DusterKid] #2736164
01/24/20 02:49 PM
01/24/20 02:49 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Money spent on maximum adjustability and strength is money well spent. Coilovers? Decent shocks are also a must.
What is your chassis shop guy recommending?
Backhalving the car? Minitub with stock frame rails? Really, with the systems and parts available for leafs these days, I don't think I would bother with ladders unless I was going to a big tire. Just getting the car lower can be done with leafs. And it can be made to hook.
Re: who has a good quality ladderbar kit for a mopar [Re: CMcAllister] #2736183
01/24/20 03:41 PM
01/24/20 03:41 PM
Washington
madscientist Offline
Washington
Why ladder bars? If you are using leaf springs a Calvert style bar is just as good. If you are going to coil overs, use a 4 link. A ladder bar is always too short and the IC will always be too high because of how short the bars are.
Re: who has a good quality ladderbar kit for a mopar [Re: madscientist] #2736194
01/24/20 04:14 PM
01/24/20 04:14 PM
PA.
"Little"John
"Little"John
PA.
I have two ladder bar cars and one I hope to be in the low 8’s on caltracks. I agree if I had caltacks I could never See me switching it to a ladder bar car. I know what caltracks are capibile of.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: who has a good quality ladderbar kit for a mopar [Re: mopar dave] #2736197
01/24/20 04:30 PM
01/24/20 04:30 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Dave... Dave... Dave... You need ladder bars like I need another carburetor.
FWIW, I'm down to four (4). tonguue
Re: who has a good quality ladderbar kit for a mopar [Re: madscientist] #2736199
01/24/20 04:40 PM
01/24/20 04:40 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Exactly!
Leaf spring and shock technology has come a long way in the past decade.
'63 Dodge 330
11.19 @ 121 mph
