Vacuum reservoir or electric pump for big cam?
#2734601
01/19/20 06:47 PM
01/19/20 06:47 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
For those that have used a vacuum reservoir how did it work for you? I'm looking at 8" of idle vacuum in my W200. The reservoirs are cheap, the electric pumps not so much. I think I can convert to hydroboost for about the same amount of money, just a lot more work.
Re: Vacuum reservoir or electric pump for big cam?
[Re: Guitar Jones]
#2734618
01/19/20 07:23 PM
01/19/20 07:23 PM
Posts: 4,737 Moved to N.E. Tennessee
GomangoCuda
Don't waste your time on the reservoir. Junkyard should have a bunch of oem vacuum pumps for a lot less than the after market. Changing over to manual brakes works better than either one.
[Re: Guitar Jones]
#2734621
01/19/20 07:29 PM
01/19/20 07:29 PM
moparpollack
Lil Herman
Lil Herman
85086
What about hydroboost?
[Re: moparpollack]
#2734637
01/19/20 08:56 PM
01/19/20 08:56 PM
Guitar Jones
What about hydroboost? I've already done the conversion on my 92, I might have spent $200-$250 on it but it is a good amount of work and some fabrication. It does however provide for some awesome brakes and is the best option, just more than I want to do right now. Not sure converting to manual brakes (which is what I've always done in the past on cars) is a good idea on a 3/4 ton truck. So what vehicles could I find an electric vacuum pump on in the junk yard?
[Re: Guitar Jones]
#2734652
01/19/20 09:43 PM
01/19/20 09:43 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
Hydroboost is probably the best option overall.
If you do a vacuum pump, a 2011-2016 Cruze should be an easy one to find, has a nice isolated bracket that should be easy to retrofit onto a different vehicle. It's located on the driver's side framerail near the bottom. You can grab a check valve, vacuum switch, etc all from the same car that should get you where you need to go.
I believe all of them with the 1.4L Turbo and an automatic have one.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: goldduster318]
#2734693
01/19/20 11:29 PM
01/19/20 11:29 PM
GomangoCuda
Many GM vehicles that are turbocharged or have auto start/stop have vacuum pumps. Reasonable price pump Power Brake Booster Vacuum Pump Assembly 20804130 31317530 Amazon link
[Re: Twostick]
#2734715
01/20/20 12:50 AM
01/20/20 12:50 AM
Guitar Jones
I would have thought the hydroboost would be more $$ than that.
A new electric pump on Amazon is similar money and should be a lot less work to install. The salvage yard solution would be the cheapest. Lots of GM cars used those as well as other makes.
Kevin It might have been more I didn't keep track but a junkyard booster and seal kit is less than $80. Add in a master cylinder, hoses and fluid and it's not that much. I replaced the P/S pump as well on mine to the 2nd gen style to get the two return nipples but you don't have to, you can just tee into the existing return line. This installation would most likely need custom hoses though. Thanks for the info guys. That Amazon pump looks like it would work.
[Re: GomangoCuda]
#2735155
01/21/20 03:54 AM
01/21/20 03:54 AM
Posts: 2,468 Sydney,Australia
tex013
Sydney,Australia
Don't waste your time on the reservoir. Junkyard should have a bunch of oem vacuum pumps for a lot less than the after market. Changing over to manual brakes works better than either one. I am with the go manual , i did . I had tried resovoir and electric pump , pump just never lasted . Granted this was a Comp type pump . I have used the GM type pumps with a pressure switch no resovoir on customer car , it seems to be working ok so far . I have 4 wheel disc brakes now and they are fine . Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
