Vacuum reservoir or electric pump for big cam? #2734601
01/19/20 06:47 PM
01/19/20 06:47 PM
Guitar Jones Offline OP
For those that have used a vacuum reservoir how did it work for you? I'm looking at 8" of idle vacuum in my W200. The reservoirs are cheap, the electric pumps not so much. I think I can convert to hydroboost for about the same amount of money, just a lot more work.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Vacuum reservoir or electric pump for big cam? [Re: Guitar Jones] #2734618
01/19/20 07:23 PM
01/19/20 07:23 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Don't waste your time on the reservoir. Junkyard should have a bunch of oem vacuum pumps for a lot less than the after market. Changing over to manual brakes works better than either one.
Re: Vacuum reservoir or electric pump for big cam? [Re: Guitar Jones] #2734621
01/19/20 07:29 PM
01/19/20 07:29 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
What about hydroboost? eek
Re: Vacuum reservoir or electric pump for big cam? [Re: GomangoCuda] #2734630
01/19/20 08:23 PM
01/19/20 08:23 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted by GomangoCuda
Don't waste your time on the reservoir. .
iagree beer
Re: Vacuum reservoir or electric pump for big cam? [Re: moparpollack] #2734637
01/19/20 08:56 PM
01/19/20 08:56 PM
I've already done the conversion on my 92, I might have spent $200-$250 on it but it is a good amount of work and some fabrication. It does however provide for some awesome brakes and is the best option, just more than I want to do right now. Not sure converting to manual brakes (which is what I've always done in the past on cars) is a good idea on a 3/4 ton truck.
So what vehicles could I find an electric vacuum pump on in the junk yard?
Re: Vacuum reservoir or electric pump for big cam? [Re: Guitar Jones] #2734652
01/19/20 09:43 PM
01/19/20 09:43 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
Hydroboost is probably the best option overall.
If you do a vacuum pump, a 2011-2016 Cruze should be an easy one to find, has a nice isolated bracket that should be easy to retrofit onto a different vehicle. It's located on the driver's side framerail near the bottom. You can grab a check valve, vacuum switch, etc all from the same car that should get you where you need to go.
I believe all of them with the 1.4L Turbo and an automatic have one.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Vacuum reservoir or electric pump for big cam? [Re: goldduster318] #2734691
01/19/20 11:25 PM
01/19/20 11:25 PM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
I would have thought the hydroboost would be more $$ than that.
A new electric pump on Amazon is similar money and should be a lot less work to install. The salvage yard solution would be the cheapest. Lots of GM cars used those as well as other makes.
Kevin
Re: Vacuum reservoir or electric pump for big cam? [Re: goldduster318] #2734693
01/19/20 11:29 PM
01/19/20 11:29 PM
GomangoCuda Offline
GomangoCuda  Offline
Many GM vehicles that are turbocharged or have auto start/stop have vacuum pumps.
Reasonable price pump
Power Brake Booster Vacuum Pump Assembly 20804130 31317530
Amazon link
Re: Vacuum reservoir or electric pump for big cam? [Re: GomangoCuda] #2734710
01/20/20 12:45 AM
01/20/20 12:45 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
Reservoir was fine for me
Re: Vacuum reservoir or electric pump for big cam? [Re: Twostick] #2734715
01/20/20 12:50 AM
01/20/20 12:50 AM
Kevin
It might have been more I didn't keep track but a junkyard booster and seal kit is less than $80. Add in a master cylinder, hoses and fluid and it's not that much. I replaced the P/S pump as well on mine to the 2nd gen style to get the two return nipples but you don't have to, you can just tee into the existing return line.
This installation would most likely need custom hoses though.
Thanks for the info guys. That Amazon pump looks like it would work.
Re: Vacuum reservoir or electric pump for big cam? [Re: Guitar Jones] #2734822
01/20/20 10:55 AM
01/20/20 10:55 AM
moparx Offline
moparx  Offline
wouldn't a reservoir help keep the pump from running all the time ?
just wondering.
beer
Re: Vacuum reservoir or electric pump for big cam? [Re: moparx] #2734861
01/20/20 12:22 PM
01/20/20 12:22 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
OEMs have been using vacuum pumps since the late '80s.
I use a GM one (from a junkyard) that makes about 5" for a pan-evac system on the race car.
It does make some noise, about like an electric fuel pump but more like a whistle than a buzz.
I use a relay and it's wired into the Run side of my ignition.
Re: Vacuum reservoir or electric pump for big cam? [Re: GomangoCuda] #2735155
01/21/20 03:54 AM
01/21/20 03:54 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
I am with the go manual , i did .
I had tried resovoir and electric pump , pump just never lasted . Granted this was a Comp type pump . I have used the GM type pumps with a pressure switch no resovoir on customer car , it seems to be working ok so far .
I have 4 wheel disc brakes now and they are fine .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
